I recently installed keil u5 and after successful installation when I open run the application it is throwing an error message "Can not read TOOLS.INI" file. I checked the TOOLS.INI path displayed in the dialogue message. It is correct. Two or three times I reinstalled the application and afterall the error is same. Any help will be great appreciated.
System OS - windows 7 64 bit
Keil Version - MDK ARM version 5.29
Regards,
RHS
Please open a Support Ticket according to: http://www2.keil.com/support/silver - thanks
I just made a test on a Win7 pro 64bit PC. MDK v5.29 works fine without the error shown in your screenshot. Therefore, it should be something local in your PC, which causes such an issue
RHS said:I checked the TOOLS.INI path displayed in the dialogue message. It is correct.
and can you open the file with a text editor; eg, Notepad?
