I'm very new in Keil software and I'm trying to setup my development enverionment.
My MCU is a STM32F746VET and I have generated the porject with the help of STM32CUBEMX. I have imported the generated files to the last version of Keil uVision5. I need to use the Keil RTX operating system, then using the software package I have installed the libraries and using the Manage Run-Time Environment I have attached to my project the following modules:
- CMSIS -> CORE
- CMSIS -> RTOS -> Keil RTX
- Device -> Startup
For the compilation, I'm using the GCC Compiler (GNU) for ARM projects with the Prefix "arm-none-eabi-".
The compilation is done correctly, but the program doesn't work (the program consists in a simple task that enables/disables a LED).
I think that the problem is involved in the operating system functions that all UNDERLINED, as we can see in the following image:
How can I fix this problem? Why all the functions are underline? I don't know about Keil and I don't understand why it is happening.
Thank you in advance.
