So, my laptop decided to go BSOD on me while i was working in keil, i had saved the file 5 minutes ago yet i fear the proyect has gone corrupt. Any sugestions?
I had onedrive autosave turned on, but restoring the modified files to a previuos week didn't work either, bear in mind that i didn't compile it, i just saved the changes in main.c
This is what i see when opening the proyect file:
Also i saw this:
Guess you could search through the memory dump and see if any of your code is visible.
Not sure why the save history in onedrive wouldn't work.
Marcoccio said:Also i saw this
the picture seems to be missing/broken.
Marcoccio said: i fear the proyect has gone corrupt
What makes you think that?
Are you sure it's not just the main.c file?
Do you have version control?
I'm supposing that OneDrive was to be doing that, at least in the sense of keeping a trail of changed files, but perhaps also the cause of the BSOD/Fail
File looks cross-linked at this point. So if you haven't archived the project, it is probably lost.
does chkdsk work on OneDrive ... ?
Hi! Sorry the late reply, it worked, but not througt the windows menu, i had to search for it in onedrive online. I have no idea why that happend.
Thanks again!.
