Hi
I'm a student doing an experiment.
I want to use an exe file to automatically change the version number in a .h file.This exe file is called before keil compiles and is compiled after the version number is increased.
After setting the options in keil, I click build/rebuild, but nothing happens.The version number was not increased, and the compile output box did not report an error.But if I double-click on the exe file, it works fine.
Did I set it up wrong?Keil 5.26.2
thanks
tangyu
Look for a dependency file in your output directory. The file will be named project_target.dep, where project is the uVision project file name and target is the build target (Target 1 in your case).
The dependency file should contain a line like this:
I (Version.h)(0x12345678)
If it doesn't have a line like this (the hex number will be different), then the build system doesn't see Version.h as a dependency of any project file. So changes in Version.h won't cause anything to be rebuilt.
Also, the uVision text editor should notice if Version.h is actually changed on-disk when you have it open in the IDE.
Thank you for your reply.I think I may have found the answer.
I put the exe file and the.uvprojx file in the same directory and it worked fine.
But I don't know why separate calls into different folders don't work.
were you using a relative paths?
