Hi
I'm a student doing an experiment.
I want to use an exe file to automatically change the version number in a .h file.This exe file is called before keil compiles and is compiled after the version number is increased.
After setting the options in keil, I click build/rebuild, but nothing happens.The version number was not increased, and the compile output box did not report an error.But if I double-click on the exe file, it works fine.
Did I set it up wrong?Keil 5.26.2
thanks
tangyu
Try Rebuild All, other build options likely observed if any of the dependencies changed
