Hello !
I wrote a RTX bootloader at 0x0 using LAN Ethernet (for updating) and uart (for debuging) to jump to the USER application at 0x00080000 address.
I try the following with my boot :
https://github.com/UltimateHackingKeyboard/bootloader/tree/master/apps/led_demo/MK64F12/mdk/led_demo_freedom_a000
I changed the scatter file from 0x0000a000 to 0x00080000 and The jump works !
I copy the bootloader and modify it to get my USER APP.
The problem is that the bootloader jump again and again
If I use the bootloader from the github source the jump works !
https://github.com/UltimateHackingKeyboard/bootloader/tree/master/targets/MK64F12/mdk/freedom_bootloader
Thank you for help
Hello
Am I the only one with this problem ? No idea why my bootloader issues ?
I can give the "home" loader for windows to send firmware and test that.
Thank you for help me
