Hi all
I am working through canprimer_v2.pdf, and opened \CAN.uvproj, selected Simulator, Debug tab has 'use simulator' selected. I then get an error:
Could not load file:
.../flash/CanDemmo.axf
Thanks,
If you had tried to build it, perhaps review the errors that prevented the build to complete successfully.
If you changed the target via "Select Target" box, you'll need to rebuild for the new selection.
OK, thanks, and apologies for the title, it doesnt reflect the problem I had.
Suggests the project hasn't actually been built successfully
