Using uVision v5.27.1.0 (RTOS 1) with STM32L4xxx. In an ISR two different signals are sent to the same thread like below:
osSignalSet(myTask, SIGNAL_1);
osSignalSet(myTask, SIGNAL_2);
In the waiting task myTask, the following code is executed:
for (;;) {
osEvent evt = osSignalWait(0, osWaitForever);
u32 signals = evt.value.signals;
The "signals " will NOT contain SIGNAL_2. Only SIGNAL_1. In other words, the waiting task will wake up on the first of the two signals, even though both of them were posted in the same ISR at the same time.
I think it is a bug .
The work around would be, in general case, to add the following code to code above:
evt = osSignalWait(0, 0);
signals |= evt.value.signals;
Now both SIGNAL_1 and SIGNAL_2 are consumed, and are in the variable "signals " .
Cheers!
