Hi all,
I am a beginner in the embedded field . I have been using keil v5 in windows 7 , while I installed the latest version 5.28 in windows 10 it crashes while launching. The file menu is missing and in place of thata a dummy filed is there. I have attached a photo.
Is this any compatibility issue. I have installed the latest version on keil v5( 5.28) and arm compiler c.Have anyone faced this issue?
Does the application actually crash/terminate or does it hang?
a) can you try to launch UV4.exe from the command line specifying a non existing project filename e.g. foo.uvprojx ? Does it launch then?
b) what type of license do you use?
c) what's your installation directory?
Probably you should raise a support ticket.
~ Joachim
Thanks for the reply,
The application crashes while starting,not getting hang.
I am using the Lite edition of Keil v5.
While launching UV4.exe from cmd it still terminates.
Installation directory is C:\Keil_v5\UV4
I have also re-installed the application.
The application starts fine sometimes but crashes when opening/compiling a project.
In order to rule out that you are seeing issues with the Dynamic Syntax checking.
Could you please try to rename c:\Keil_v5\UV4\UVAC.dll before launching UV4.exe ?
Thanks,
Renamed the file but the problem still persisits
Please raise a support ticket.
