I am running an application on the simplelink evaluation board MSP-EXDP432E401Y with the XDS110 debugger that is integrated into the eval board. When I insert a breakpoint into an ISR the break happens but I am unable to do anything but hit run again. There is no single stepping capability. Single stepping works fine outside the ISR. Is there a compiler setting that should be set?
groupalpha said: I am asking is this a problem with the IDE, or possibly the XDS110 debugger I am using.
Again, you could narrow that down by trying a different debugger and/or trying a different IDE.
