I have already ported Freertos kernel file in my project, but after building the code showing error in configuration file. Please suggest someone.
And if anyone wrote the code for IMU sensor(MPU9250) in Freertos.Please help regarding that...
Anupam Mishra said:after building the code showing error in configuration file. Please suggest someone
So correct those errors, then!
Does this have anything to do with Keil?
Surely, FreeRTOS configuration is a question for https://www.freertos.org/ ?
The IMU (or any other device) neither knows nor cares whether you use an RTOS - let alone which RTOS it is.
So that shouldn't affect the code.
If you want tutorials on how to use FreeRTOS, go to https://www.freertos.org/
