Hi
I am beginner in assembly language. I want to convert uppercase to lowercase. i am using keil software.Codes which are searched by me on google i try to run but their output
invalid.i am using stm32l476VG. Can anyone help me .Code with commenting .Thank you
That's your homework. You do it.
Back in the day we had text books that explained ARM Assembler in an incremental/progressive form. Perhaps you should try to understand the underlying mechanics here before Googling an answer you lack the foundation to assimilate.
Perhaps implement in a language you do understand, and then expand/translate from there?
if ((a >= 'A') && (a <= 'Z')) a += ('a' - 'A');
Babar Sohail said:I am beginner in assembly language
Some book suggestions for you:
http://www.keil.com/books/armbooks.asp
In particular, Joseph Yiu's Definitive Guide to ARM® Cortex®-M3 and Cortex®-M4 Processors has chapters on the Instruction Set and Assembler programming...
The Keil Assembler User Guide is here:
http://www.keil.com/support/man/docs/armasm/armasm_dom1359731119400.htm
Babar Sohail said:I want to convert uppercase to lowercase
Do you understand how to do that in general - without the use of Assembler?
Babar Sohail said:Codes which are searched by me on google i try to run but their output invalid
In what way "invalid" ?
Have you checked those codes to understand what they're doing?
What debugging have you done?
it"s not my homework. i am just trying some code in keil as i have try arithmetic operation ,for and while loop.
AsWestonsupermare Pier says, just "trying" random code isn't a terribly effective learning approach.
You need a proper tutorial and/or textbook which will begin at the beginning and work you through, step by step, in a logical and progressive course of learning.
I might suggest books by JR Gibson, Bruce Smith, or Ali Mazadi
Unfortunately hard to critique code I can't see, and search results that aren't cited. Formulate better questions, you'll get better answers...
