i compiled successfully an .axf Image sucessfully with CMake in my CLion Environment.
One further Question:
On http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm is described how to use the flashing/download manually on command line.
Examples:UV4 -f PROJECT1.uvprojx -t"MCB2100 Board"
When I use it uVision opens and downloads the image and closes itself afterwards. Is there a more smooth way?
Like seeing the progress in command line or suppressing the opening of the keil uVision Window?
Or even better: Directly integrated in CMake?
I read i can create an .hex file from an .axf file with fromelf.exe. Do you have any recommandations of flashing the image?
You've already asked that question:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/44208/using-arm-toolchain-in-cmake/160368#160368
