Using NUCLEO-G071RB evaluation board via embedded ST-Link.
Started with a new project from scratch.
This is my main():
#include <cmsis_os.h> // ARM::CMSIS:RTOS:Keil RTX int main (void) { osKernelInitialize(); osKernelStart(); osDelay(osWaitForever); while (1) ; }
After some time debugger crashes.
Uncommenting RTX related calls, the while(1) runs ok.
What is such fundamental wrong here ?CMSIS core is 5.3.0, RTX is 4.82.0 , device stratup is 1.3.0, device is STM32G071RBTx, DFP is 1.2.0.
The title says, "minimal program"; but you are using an RTOS - which is far from minimal!!
Is your code from an unmodified, known-good example specifically for that board?
If not, I would strongly suggest that you start with such an example!
Or, in fact, start with a truly minimal example - no RTOS !
