PC-Lint on KEIL C
I use KEIL C evaluation version as following with PC-Lint (v1.3 fro evaluation version)
Tool Version Numbers:
Toolchain: MDK-Lite Version: 5.28.0.0
And using below configuration to check MISRA-C
But after I launch "Lint ALL C/C++ Source Files", there have warning message and error message output from the KEIL C, such as following,
Is that correct? How could I fix this issue?
When PC-Lint start to check source files, there have error message output such as following, but I don't think there has error for ';' or unknown type 'uint64_t' because
compiler can build this project successfully, I think that some configuration does not set correctly. Thank you very much, I appreciate someone can provide me with some
suggestions on this topic, thanks again.
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
