Good morning
Is there a way to memcpy from SFR's in the C51?
I have tried to memcpy((char*)&buffer, (char*)&CAN0IF2DA1L, 8); but it doesn't work
Other things i tried
memcpy((char*)&buffer, CAN0IF2DA1L, 8); //error C214: illegal pointer conversion
memcpy((char*)&buffer, (char*)&CAN0IF2DA1L, 8); //error C189: '&' on bit/sfr illegal
Any ideas?
Richard
Are the registers even contiguous?
*p++ = CAN0IF2DA1L;*p++ = CAN0IF2DA1H;
given that SFR space isn't indirectly accessible, I guess the whole question is moot?
RichardT said:memcpy((char*)&buffer, (char*)&CAN0IF2DA1L, 8 );
and, as we're only talking 8 bytes anyhow, eight direct assignments is almost certainly going to be the quickest solution.
Unless the chip has some DMA tricks ...
But RichardT seems to have lost interest.
Andy Neil said:given that SFR space isn't indirectly accessible, I guess the whole question is moot?
Agreed
Andy Neil said:and, as we're only talking 8 bytes anyhow, eight direct assignments is almost certainly going to be the quickest solution.
Length is dynamic but in my case maximum of 8 bytes
Andy Neil said:Unless the chip has some DMA tricks ...
No tricks here
Andy Neil said:eight direct assignments
I tried googling the "CAN0IF2DA1L" from the OP, and found this: https://gist.github.com/petscare/3884991 - which does exactly that:
// copy message into CAN0rx; m->Data[0] = CAN0IF2DA1L; m->Data[1] = CAN0IF2DA1H; m->Data[2] = CAN0IF2DA2L; m->Data[3] = CAN0IF2DA2H; m->Data[4] = CAN0IF2DB1L; m->Data[5] = CAN0IF2DB1H; m->Data[6] = CAN0IF2DB2L; m->Data[7] = CAN0IF2DB2H;
Andy Neil said:I tried googling the "CAN0IF2DA1L" from the OP, and found this: https://gist.github.com/petscare/3884991 - which does exactly that:
I have been using very similar code for a while now.
The can protocol gives the length of the packet (being 1 - 8 bytes) so I wanted to try copy the exact number of bytes into my rx buffer for processing.
No point passing the invalid characterst but it seems like the most efficient way of doing this is to copy all 8 bytes every time
RichardT said:seems like the most efficient way of doing this is to copy all 8 bytes every time
Well, doing work that serves no purpose is very rarely the most efficient way of doing anything.
This also probably applies to the case at hand. Watch, be appalled, and learn: ;-)
// copy message into CAN0rx; switch(dlc) { case 8: m->Data[7] = CAN0IF2DB2H; case 7: m->Data[6] = CAN0IF2DB2L; case 6: m->Data[5] = CAN0IF2DB1H; case 5: m->Data[4] = CAN0IF2DB1L; case 4: m->Data[3] = CAN0IF2DA2H; case 3: m->Data[2] = CAN0IF2DA2L; case 2: m->Data[1] = CAN0IF2DA1H; case 1: m->Data[0] = CAN0IF2DA1L; case 0: }
This is one half of what may be the only C code snippet infamous enough to carry a name of its own: Duff's Device.
Broeker said:Duff's Device
was about to say that - you beat me to it!
Broeker said:the only C code snippet infamous enough to carry a name
Algol has Jensen's Device
