I'm using keil with STLINK, connected to a GD32F130C8.
I can see, in debug, by means of Watch, variables changing in real time.
Everything works fine.
Now I would like to enable trace, in order to see the evolution of a variable in time domain, thru logic analyzer.
I enabled trace flag on trace tab (setting menu), I set, on trace tab, the processor speed (72MHZ).
The problem is that logic analyzer doesn't show requested float variable, and on the bottom of the screen I read the sentence "Trace: No Synchronization".
The output of SystemCoreClock() function gives 72Mhz.
any hint?
ema vac said:Search “trace” on this page
The only mention of trace on that page is saying that you can use the ULINK-pro - which has trace capability.
It doesn't say that the chip has trace capability.
ema vac said:In the user manual of gd32 processor I can also read
Again, for clarification of their documentation, and/or their chip's features & capabilities - you need to contact them.
In the user manual of gd32 processor I can also read the following:
The CortexTM-M3 processor is based on the ARMv7 architecture and supports both Thumb and Thumb-2 instruction sets. Some system peripherals listed below are also provided by CortexTM-M3: Internal Bus Matrix connected with I-Code bus, D-Code bus, System bus, Private Peripheral Bus (PPB) and debug accesses (AHB-AP) Nested Vectored Interrupt Controller (NVIC) Flash Patch and Breakpoint (FPB) Data Watchpoint and Trace (DWT) Instrumentation Trace Macrocell (ITM) Serial Wire JTAG Debug Port (SWJ-DP) Trace Port Interface Unit (TPIU)
Search “trace” on this page:
www2.keil.com/gigadevice
For that example, you can look at the schematics and/or the User Manual of the board.
ema vac said:looking at darasheet of my processor, I can’t find any reference to SVW or SWO
As I asked before, what makes you think that your processor does support it?
You would need to contact the chip manufacturer for specific details ...
There is something i’m Not understanding:
the example that I cited says:
Additional Serial Wire Viewer (SWV) Information:Serial Wire Viewer data (frames) are output on the 1 pin SWO. This pin is located on 13 on the 20 pin legacy connector (the BIG one). It is also available on the 10 or 20 pin CoreSight Debug connectors. SWO is on pin 6 on the 10 pin and pin 14 on the 20 pin. SWO is multiplexed with JTAG TDO pin. This means SWD (Serial Wire Debug) must be used and not JTAG mode. This is easily set in μVision. SWD = SW in μVision. ST-Link/V2 supports SWD only and not JTAG.
This information don’t tells me where should I connect each pin of the stlinkV2. It just tells which pin of stlinkV2 shall be used.
to be more clear, i’m not using a development board with ST chip on it, but a board of a developed board. So I need to know which pin of the processor should I connect to the stlinkV2.
looking at darasheet of my processor, I can’t find any reference to SVW or SWO.
Again, why don't you go back to the example you cited earlier - get that working, and then you'll have the understanding to know what to do ...
Please let me better understand trace:
now I use clock and data to flash firmware and to watch variables.
do I need to use one more pin to receive trace data?
according to the previous shared link I can add SWO pin to my cheap st link clone.
Then where should I connect SWO ? On which pin of my GD32 chip?
yes - that looks like the kind of thing.
lujji.github.io/.../
come to think of it, ISTR seeing something on the interwebs about hardware hacks to get these cheap ST-Link knock-offs to do Trace...
ema vac said:Can you send me some link where it is written that my problem is related to the stlink emulator
Again, have you tried the example you mentioned - using a genuine ST-Link?
If you have followed that, and that doesn't work, then there's something to work with.
Ok, thank you, don’t comment
Please understand that I am not commenting on a setup that includes a usage of such copies
Can you send me some link where it is written that my problem is related to the stlink emulator?
You should never buy such copies. This just ends up in lost time as you see here. Order the original tools when programming a microcontroller - then i.e. you can expect a professional support
