Hello friends
I am trying to generate PWM using TIM4 in STM32F446ZE, But There is no proper output from the controller
Here i am sharing my code with you, please help me out
Counter register increments properly
Specifications
CLK_FREQ =16Mhz (internal)
Timer = TIMER4 and CHANNEL 4
PIN = PD15
PWM freq = 1Khz
Duty cycle = 50%
PWM mode = 1
#include "stm32f4xx.h" // Device header#include "RTE_Components.h" // Component selection
int main(){ RCC->AHB1ENR&=0; RCC->AHB1ENR|=1<<3; // Enable PORT D RCC->APB1ENR&=0; RCC->APB1ENR|=1<<2; // Enable TIMER4 GPIOD->MODER&=0; GPIOD->MODER|=0X80000000; // PD15 as Alternate function GPIOD->AFR[1]&=0; GPIOD->AFR[1]|=1<<28|1<<29; // Alternate function 2 ( AF2) , since PD15 so AFR[1] GPIOD->OSPEEDR&=0; GPIOD->OSPEEDR|=0X80000000; // High Speed output enable TIM4->CCER&=0; TIM4->CCER|=1<<12; // CCP 4 enable ( Since Channle 4) TIM4->CR1&=0; TIM4->CR1|=1<<7; // ARPE enable ( Auto reload preload enable TIM4->CCMR2&=0; TIM4->CCMR2|=1<<14|1<<13|1<<11; // PWM Mode 1 selected and output compare 4 preload enable TIM4->PSC&=0; TIM4->PSC|=16; // prescale as 16 , Since PWM Freq =1Khz TIM4->ARR&=0; TIM4->ARR|=1000; TIM1->CCR4&=0; TIM1->CCR4|=500; //50 % duty cycle
TIM4->BDTR&=0; TIM4->BDTR|=0X8000; TIM4->EGR&=0; TIM4->EGR|=1<<0; TIM4->CR1|=1<<0; // Enable the counter}
Probably this helps "STM32 PWM (2) Example":
http://www.keil.com/download/docs/355.asp
Actually i followed the datasheet as STM specified and accessed the registers, even though there is no output, I doubt that there must be some more registers to be accessede
Checking at ST sites, I found this demonstration: https://stm32f4-discovery.net/2014/05/stm32f4-stm32f429-discovery-pwm-tutorial/
This seems good
I think I initialized the same registers as they mentioned .
Anyway once again i want to read it thoroughly
Thanks for your time
Hello KopschI went through the link which you shared , but there is no proper informationIs there any way to get the registers to be initialised .
NMJ said:Is there any way to get the registers to be initialised
You write code to do that!
I strongly recommend to follow our demonstrations at
- http://www.keil.com/download/docs/355.asp
- and http://www.keil.com/download/docs/354.asp
and the way Keil is managing the generation of pulse-width modulation.
If you get this running I am expecting that you're successfully managing
the register handling with your indivdual approach.
However, let me finally point you to another solution at:
http://www.hit-karlsruhe.de/hit-info/info-ss14/KamerabefestigungVC25C/quellcode.html
Andy Neil
Thanks for the information.
hereafter I will do proper care on posting source code
