I got a discovery kit .(stm32l discovery kit) when i try to load some basic
blinky code to my processor - after the compiling - I got some error mesage ;
"No target connected " and "Error : Flash download failed target dll has been canceled "
after this message i did some actions for solving this problem (for example ;
I did ; Utilities --> Debug ---> Connect ---> Choose ,Reset after Connect) but
Nothing solved.
I am demanding your valuable suggestions...
I had the same issue with my discovery board. Changing the cable solved the issue..
Bad USB cables or charging cables can be an issue. Typically the PC won't find the ST-LINK USB device at all in such circumstances.
The OP had a system where the USB device was found, but the Target MCU was unresponsive.
