Hello i'm new in this forum, I have a issue with keil, I try to learn more for adc and other things with the stm32f103c8 (I bought 4 it's very cheap XD), in the firts time I do the blink led, then I try the debugger and it was work properly.When I try to check a variable in mode ADC the st link debugger doesn't do anything. I return my code to the blinker led and the issue keep, keil doesn't debug.I read something similar in this issue to and download the firmware version for the st link but keil doesn't work with them.
community.arm.com/.../keil-crashes-during-flash-or-debugger-settings-button-clicked-with-stlink
st link version downgrade
st link version, functional version for keil
keil debug mode, apparently is functional... but
when I use the red circle function, keil doesn't do anything, the
example, as you can see the double cross doesn't appear.
Thank for your time, I'm from Mexico I don't know if my expression it's really good.
The configuration from Cube MX, I put the serial cable in SYS because in Atollic it is also a problem to debug. But in Kiel it doesn't work.
The 0x1FFFF000 address range suggests it is executing from ROM, and not your FLASH based code. Make sure the BOOT0 pin is LOW
Keil does not redirect execution, unless you use a debugger script, or manually set the PC (Program Counter)
Oh man!!, I wasting my time for many days, I was try that with the boot0 in low but in keil labels warnings appears , the debug are offline and when I put in high the stm32 was flash but the debugger doesn't work. Thanks a lot.
At the same with Atollic, in cubeMX "SYS" serial wire need active.
