L251 user defined memory classes
It is said in the L251 documentation that by default, the linker would use below address ranges for a all memory classes
Question 1:
In a linker file that i was checking,  the two are declared in the input directive file
HDATA (0x100-0x2EBF),
HDATA_EEP (0xF80080-0xF800E0),
is the range of HDATA_EEP valid? I thought that because of the first declaration, we are limiting the HDATA memory space from 100 to 2EFB only.
Question 2:
If the above HDATA_EEP declaration is valid..
then is this the correct pragma to use?
#pragma userclass(hdata = eep)
