Greetings,
Intro: I am developing a TCP Server (TCP Passive Open) using LPC2364 (ARM7TDMI). I need to transmit/ receive approximately 35 Kb of data through an active TCP connection. As per document references, the TCP_MAXSEGSZ macro defines the maximum size of the packet transmitted in a single transaction. The possible range that can be defined is between 536 to 1460 bytes.
Issue: Even if I configure the maximum value 1460 as the Maximum segment size(TCP_MAXSEGSZ ), I am able to transmit only 554 bytes through an active connection.
I also came across the statement of Keil that the Maximum Segment size will be negotiated during initial handshake of the TCP connection. But the TCP client I am communicating with, is a Linux based system which has a minimum value of 4096 as Maximum Segment Size.
How can I solve this issue?
Requirement: I need the Maximum Segment size during transmission to be at least 1024 (1Kb).
Kindly help me out in this regard. Thanks in advance.
Thank you - Andy Neil, Kevin, ChenTang. Kevin, I used the patch which you mentioned. But as ChenTang has quoted, it didn't wok for the LPC2364. Iam using the old RL_TCPNet library. ChenTang, I agree with the method to know the reason why it is restricted to 554 bytes. So, I changed the TCP client device. I used a Windows based software "TCP test tool". Even with this tool the restriction persists. So, I assume that the issue is in the micro-controller (LPC2364) side. I have quoted all the configurations I have made for the TCP connection. Kindly have a look and thanks in advance for your extended support Andy Neil, Kevin. ChenTang.
// </e> // <e>TCP Sockets // ============== // <i> Enable or disable TCP Sockets #define TCP_ENABLE 1 // <o>Number of TCP Sockets <1-20> // <i> Number of available TCP sockets // <i> Default: 5 #define TCP_NUMSOCKS 1 // <o>Number of Retries <0-20> // <i> How many times TCP module will try to retransmit data // <i> before giving up. Increase this value for high-latency // <i> and low_throughput networks. // <i> Default: 5 #define TCP_MAXRETRY 5 // <o>Retry Timeout in seconds <1-10> // <i> If data frame not acknowledged within this time frame, // <i> TCP module will try to resend the data again. // <i> Default: 4 #define TCP_RETRYTOUT 4 // <o>Default Connect Timeout in seconds <1-600> // <i> Default TCP Socket Keep Alive timeout. When it expires // <i> with no TCP data frame send, TCP Connection is closed. // <i> Default: 120 #define TCP_DEFTOUT 120 // <o>Maximum Segment Size <536-1460> // <i> The Maximum Segment Size specifies the maximum // <i> number of bytes in the TCP segment's Data field. // <i> Default: 1460 #define TCP_MAXSEGSZ 1460 // <o>Receive Window Size <536-65535> // <i> Receive Window Size specifies the size of data, // <i> that the socket is able to buffer in flow-control mode. // <i> Default: 4380 #define TCP_RECWINSZ 4380 /* TCP fixed timeouts */ #define TCP_INIT_RETRY_TOUT 1 /* TCP initial Retransmit period in sec. */ #define TCP_SYN_RETRY_TOUT 2 /* TCP SYN frame retransmit period in sec. */ #define TCP_CONRETRY 7 /* Number of retries to establish a conn. */
To clarify when we talk about MSS. There are two MSSs in the TCP socket, a local receiving MSS and a remote receiving MSS.
TCP_MAXSEGSZ 1460 is the local receiving MSS on LPC2364. Linux has its own receiving MSS. It is not clear which MSS is the problem. I assume it's on Linux.
