My colleagues from the Arm Digital Signal Processing (DSP) software team have introduced a Python wrapper for the CMSIS-DSP library that is compatible with NumPy. The CMSIS-DSP library is a rich collection of DSP functions that Arm has optimized for the various Arm Cortex-M processors. CMSIS-DSP is widely used in the industry, and also enables optimized C code generation from various third-party tools.
Please read their blog here: https://developer.arm.com/architectures/instruction-sets/dsp-extensions/dsp-for-cortex-m/how-to-use-the-python-wrapper-for-csmsis-dsp-with-biquads-as-an-example
Dear Christopher! We are very enthusiastic about this wrapper and would like to use it but we keep getting errors when trying to install the package/library. I am working an MacOS and my colleague is working on Windows and we both get the same error message:
"ERROR: /Users/liselynen/OneDrive - Capetech BVBA/190521 Python Scripts/cmsdsp-tests/PythonWrapper/setup.py is not a valid editable requirement. It should either be a path to a local project or a VCS URL (beginning with svn+, git+, hg+, or bzr+)."
Can you or one of your colleagues help us out on this?
Hello Lise,
my other colleague made these comments:
"I would suggest they move it outside of OneDrive and avoid path containing spaces. But I think the issue is with OneDrive.
Also, as explained in the README, they should be in the folder containing the setup.py file and type:
python setup.py build_ext –inplace
From the error I may conclude they called setup from another folder. But not totally sure since Python may internally recompute the absolute path."
Kind regards,
Christopher
Hi Christopher,
Thanks for your help. It worked for my colleague as she installed Microsoft Visual Studio 2019 (workload 'desktop development with C++').
However I keep getting this error message: '
transform.remove(os.path.join(ROOT,"Source","TransformFunctions","TransformFunctions.c"))
ValueError: list.remove(x): x not in list'
Should I also install Visual Studio ? Or is there another reason? Does it has to do with my OS?
I tried both
pip3 install -e /Users/liselynen/Documents/cmsdsp-tests/PythonWrapper
and
Both in the correct "PythonWrapper" folder and I keep getting this error message. Does the python code take into account different operating systems? Would it be possible to discuss this topic in private with one of the application engineers? I would really like to have this solved.
I was able to find a colleague with a Mac. He reported the following:
"I did a quick test and the installation succeeded. I am using Python 3.7.0 on macOS Catalina 10.15. Couple of notes about macOS-specific changes to the README:
Hope this helps.
Thanks for the suggestion, however I already tried to install it like this but I keep getting the same error message.
To be clear I first still need to run this line "
> python setup.py build_ext --inplace" , right?And afterwards I create the virtual env and do the pip install... ?
Both unfortunately still provide me with the same error message. It seems that in line 22 of config.py something goes wrong. Probably it has to do with the os.path.join. I've really tried everything. Could you maybe show me exactly which steps your colleague took on Mac to get this installed? How does his path looks like?
I currently get another error. Is there some way to contact you in private as it's not so convenient to share all error messages on this public forum?
For support other than Windows, you need to install the develop branch, as this introduces support for other operating systems.
Hello Christopher,
I am haveing a similar problem (using jupyter notebook and typing in anaconda prompt):
- removed the folder from the OneDrive
- installed the numpy
- after going to the path and typing python setup.py build_ext –inplace -> I keep on having this errorAny suggestions, please?
Hello Tiago,
can you check if your ROOT variable is set to the right path? Take a look at the config.py file in the PythonWrapper folder and set the ROOT to the right path. It should be the path to the DSP folder. Currently there is ROOT = “..” and I this might not be robust enough.
Thank you for the fast reply.
That was really helpful.
Currently, I am having this error. Is it because I am using anaconda and/or should I move to visual studio?
Thank you,
here's a blog from Microsoft that talks about this for Anaconda users: https://devblogs.microsoft.com/python/unable-to-find-vcvarsall-bat/. I hope you will be able to download the package for Anaconda then.
Thanks again,
Last question (changes for pzthon2.7 with visual studio):
- the setup runs fine
- when opening a python notbook and running the import on the the same folder i get
ImportError: No module named cmsisdsp
Is it a problem with the setup.py?
Thanks in advance
Since it is an extension built in place, it is not installed in the Python folders. So if you are importing from the wrong working directory, the extension won’t be found. The working directory should be PythonWrapper
This is not ideal but we did not find the time for building and distributing a Python extension. So we are using the in place method.
