I am using KEIL µVision 4.74.0.0 with ARM compiler 5.03.0.76 on Windows 10.
When I put my web src files into fcarm.exe, I get absolutely no output, and also no error message. The tool calculates quite some time (maybe 10 s or so), and then outputs just nothing, neither when listing my input files directly, not using a command file.
Example:
C:\Keil\ARM\BIN\FCARM.exe @Web.inp
Where Web.inp is:
bootstrap-theme.min.css,~bootstrap.min.js,bootstrap-theme.min.css,index.cgi,io.cgi,~jquery.min.js,Logo.png,style.cssto Web.c nopr
When I leave out "nopr", then an empty "Web.lst" file is created, that's all.
Can anyone give a hint how I can check what is going wrong?
Hello hgl,
have you tried to change the "to" to 'TO"? Oh and why do you have the bootstrap-theme.min.css twice in your command file?
Kind regards,
Christopher
Hi Christopher,
thanks for your answer!
- both "to" and "TO" behave the same way
- sorry, bootstrap-theme.min.css was a copy/paste problem
I have experimented a bit and found out that my source file "index.cgi" causes the problem. When reducing the whole thing to
fcarm index.cgi to web.c nopr
then I already get no output. I have broken down the content of index.cgi to "<html><body>This is a test.</body></html>". Observation: when renaming the file to "index.html" it works. As "index.cgi" there is no output.
It seems that I need to investigate further how my predecessor developer converted this - maybe he did some preprocessing on the cgi files before using fcarm. Thank you for the support anyway, and sorry that I'm coming up with such weird stuff - I didn't start this project, just trying to continue someone else's work...
Regards, hgl
no worries! I'm happy that you're on the right track now.
