Hello, i am having trouble in flashing a simple program in to a 8051 device with a usb kit. The device i am using is a "at89c51ic2"
when i build target does not show any error or warning, but when i try to flash, this error shows up:
with this i went to the "options for target" ->"utilities" to make sure but i did not found nothing :(
this is what is the box:
"-autoisp -device $D -hardware RS232 -port COM5 -baudrate 9600 -operation MEMORY FLASH LOADBUFFER "#H" PROGRAM START RESET 00"
if anyone could help finding the problem it would be great, i am losing my mind :'(
sorry for my bad english
Andy Neil said:Why do you think that's an error ?
Oh, I see:
EuSouOVALETEbro said:--- Error: failed to execute 'batchisp -autoisp -device AT89C51RD2 -hardware RS232 -port COM5 -baudrate 9600 -operation MEMORY FLASH LOADBUFFER "C:\Keil_v5\C51\Examples\Objects\teste.HEX" PROGRAM START RESET 00'
Well, that's uVision telling you it couldn't execute that command.
So, again, can you execute that command manually from the command line?
If you get the same at the command line, then obviously uVision won't be able to execute it, either!
You will then have to contact whoever supports this "batchisp" thing ...
thank you for the response, the "batchisp" was the problem as you suggested. What happened that this 8051 usb kit was the first i used as a student before i reset my PC and lost all the necessary programs for programming this 8051 kit. yesterday i found it and wanted to try to do something with it, but i did not remembered of the total configuration of the "Keil uVision", but worst i forgot to install a program called "FILP" that it is intended to help in the communication with the 8051 kit, and when you pointed it i installed it and put the right path to it.
thank you very much :))
