Using µVision V5.28.0.0. for STM32G071.Executing TIM3->EGR |= TIM_EGR_UG; will result in correct asm code, ;;;1156 TIM3->EGR |= TIM_EGR_UG; // Force update generation (UG = 1)0000b8 4608 MOV r0,r10000ba 6940 LDR r0,[r0,#0x14]0000bc 2101 MOVS r1,#10000be 4308 ORRS r0,r0,r10000c0 491c LDR r1,|L20.308|0000c2 6148 STR r0,[r1,#0x14]butWatch of TIM3 shows SR changed instead of EGRTIM3 SR 0x00000001.Seems in any info file for MDK and STM32G0 there is a wrong offset for watch of SR/EGR stored.Where can I modify this ?Best regards
The System Viewer debug window works based on CMSIS-SVD standard, namely the *.svd and *.sfr files included in the corresponding device family pack. A wrong register offset value in such a svd file might cause the issue you observed. Since these files come from ST, if there is anything to be fixed in such svd and sfr files, you have to wait for a new pack release, which would cause you a certain of delay.
Therefore, as workaround, you could modify the corresponding offset value for a register directly in the corresponding svd file located in your pack installation folder and then call svdconv.exe based on http://www.keil.com/pack/doc/CMSIS/SVD/html/svd_SVDConv_pg.html to convert it to a sfr file. And replace both svd and sfr files in the original directory. After restarting uVision, the issue should be fixed.
SVD file is correct, also SFR file contains correct base address (0x4000 0400) and offsets for registers SR (0x10) and EGR (0x14).Proved via Memory Window:
So, µVision shows correct that SR instead of EGR has been written.
Wondering what is going wrong here...Because stm32G0xx.h file is also correct:
typedef struct { __IO uint32_t CR1; /*!< TIM control register 1, Address offset: 0x00 */ __IO uint32_t CR2; /*!< TIM control register 2, Address offset: 0x04 */ __IO uint32_t SMCR; /*!< TIM slave mode control register, Address offset: 0x08 */ __IO uint32_t DIER; /*!< TIM DMA/interrupt enable register, Address offset: 0x0C */ __IO uint32_t SR; /*!< TIM status register, Address offset: 0x10 */ __IO uint32_t EGR; /*!< TIM event generation register, Address offset: 0x14 */ __IO uint32_t CCMR1; /*!< TIM capture/compare mode register 1, Address offset: 0x18 */ __IO uint32_t CCMR2; /*!< TIM capture/compare mode register 2, Address offset: 0x1C */ __IO uint32_t CCER; /*!< TIM capture/compare enable register, Address offset: 0x20 */ __IO uint32_t CNT; /*!< TIM counter register, Address offset: 0x24 */ __IO uint32_t PSC; /*!< TIM prescaler register, Address offset: 0x28 */ __IO uint32_t ARR; /*!< TIM auto-reload register, Address offset: 0x2C */ __IO uint32_t RCR; /*!< TIM repetition counter register, Address offset: 0x30 */ __IO uint32_t CCR1; /*!< TIM capture/compare register 1, Address offset: 0x34 */ __IO uint32_t CCR2; /*!< TIM capture/compare register 2, Address offset: 0x38 */ __IO uint32_t CCR3; /*!< TIM capture/compare register 3, Address offset: 0x3C */ __IO uint32_t CCR4; /*!< TIM capture/compare register 4, Address offset: 0x40 */ __IO uint32_t BDTR; /*!< TIM break and dead-time register, Address offset: 0x44 */ __IO uint32_t DCR; /*!< TIM DMA control register, Address offset: 0x48 */ __IO uint32_t DMAR; /*!< TIM DMA address for full transfer, Address offset: 0x4C */ __IO uint32_t OR1; /*!< TIM option register, Address offset: 0x50 */ __IO uint32_t CCMR3; /*!< TIM capture/compare mode register 3, Address offset: 0x54 */ __IO uint32_t CCR5; /*!< TIM capture/compare register5, Address offset: 0x58 */ __IO uint32_t CCR6; /*!< TIM capture/compare register6, Address offset: 0x5C */ __IO uint32_t AF1; /*!< TIM alternate function register 1, Address offset: 0x60 */ __IO uint32_t AF2; /*!< TIM alternate function register 2, Address offset: 0x64 */ __IO uint32_t TISEL; /*!< TIM Input Selection register, Address offset: 0x68 */ } TIM_TypeDef; #define PERIPH_BASE (0x40000000UL) /*!< Peripheral base address */ #define APBPERIPH_BASE (PERIPH_BASE) #define TIM3_BASE (APBPERIPH_BASE + 0x00000400UL) #define TIM3 ((TIM_TypeDef *) TIM3_BASE)
Checked asm output again...
;;;1156 TIM3->EGR |= TIM_EGR_UG; // Force update generation (UG = 1) 0000b8 4608 MOV r0,r1 0000ba 6940 LDR r0,[r0,#0x14] 0000bc 2101 MOVS r1,#1 0000be 4308 ORRS r0,r0,r1 0000c0 4919 LDR r1,|L20.296| 0000c2 6148 STR r0,[r1,#0x14] |L20.296| DCD 0x40000400
At least checked device errata sheet as of Nov. 2018.No matching issue there.
Juergen
How to properly post source code:
0x40000400: 80 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 03 00 00 00 //......... CR1........ CR2........ SMCR....... DIER....... SR......... EGR........ CCMR1......
;;;1157 TIM3->DIER |= TIM_DIER_UIE; 0000b8 4608 MOV r0,r1 0000ba 68c0 LDR r0,[r0,#0xc] 0000bc 2101 MOVS r1,#1 0000be 4308 ORRS r0,r0,r1 0000c0 4922 LDR r1,|L20.332| 0000c2 60c8 STR r0,[r1,#0xc] ;;;1158 TIM3->SR |= TIM_SR_UIF; 0000c4 4608 MOV r0,r1 0000c6 6900 LDR r0,[r0,#0x10] 0000c8 2101 MOVS r1,#1 0000ca 4308 ORRS r0,r0,r1 0000cc 491f LDR r1,|L20.332| 0000ce 6108 STR r0,[r1,#0x10] ;;;1159 TIM3->EGR |= TIM_EGR_UG; 0000d0 4608 MOV r0,r1 0000d2 6940 LDR r0,[r0,#0x14] 0000d4 2101 MOVS r1,#1 0000d6 4308 ORRS r0,r0,r1 0000d8 491c LDR r1,|L20.332| 0000da 6148 STR r0,[r1,#0x14] ;;;1160 TIM3->CCMR1 |= TIM_CCMR1_CC1S; 0000dc 4608 MOV r0,r1 0000de 6980 LDR r0,[r0,#0x18] 0000e0 2103 MOVS r1,#3 0000e2 4308 ORRS r0,r0,r1 0000e4 4919 LDR r1,|L20.332| 0000e6 6188 STR r0,[r1,#0x18]
Result: Cannot write anything to TIM3->EGR.Writes to TIM3->EGR are stored in SR.Writes to DIER and CCMR1 are stored ok.Maybe one can check the binary codes in asm-txt- output.Juergen
