Event Viewer with RTX5 doesn't display separate threads
Hi
I'm running MDK 5.22 with CMSIS-RTOS2 RTX5 in a simple test using Event Viewer with a UNINK Pro on an STM32F429.
I suspect I'm doing something wrong, but I cannot figure out how to get the Event Viewer to display separate threads.
All my threads appear under main(1) as shown in this shared screenshot link: "
As you can see, the exceptions (SVCall, PendSV, SysTick, TIM3) are shown separately as one would expect.
Each of the threads are in their own C file, and have unique names.
I am using the JTAG port with the 4bit trace port set up as described here: www.keil.com/.../ulinkpro_STM32F4xx_ETM.htm
I have applied the trace settings as described on this page: www.keil.com/.../uv4_db_dbg_event_viewer.htm
My test project includes RTX5 as source, and the use of "DBG_MSG" as described in the following link, no longer seems relevant in RTX5 :http://www.keil.com/support/docs/3630.htm
Any advice will be appreciated.
Thank you.
