Here is the return statement in Cortex-M0's function NVIC_GetPriority ----
__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn) { if(IRQn < 0) { return((uint32_t)((SCB->SHP[_SHP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for Cortex-M0 system interrupts */ else { return((uint32_t)((NVIC->IP[ _IP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for device specific interrupts */ }
It does not shift off the heading bits of other IRQs. for example, if IRQn == 26 and NVIC->IP[ _IP_IDX(IRQn)] == 0x40404040, it return 0x101. The correct priority value should be 1.
__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn) { if(IRQn < 0) { return 0xFF & ((uint32_t)((SCB->SHP[_SHP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for Cortex-M0 system interrupts */ else { return 0xFF & ((uint32_t)((NVIC->IP[ _IP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for device specific interrupts */ }
Have you read the Overview of this forum? It says that Keil Support DOES NOT MONITOR this forum on a regular basis.
If you feel that you have a bug then submit a bug report. If you pay as much detail to your code as you did about posting on this forum, I doubt seriously that you have identified anything as a true bug.
http://www.keil.com/support/contact.asp
Bradford
I don't think it's the correct attitude ..
Well now. Lets examine the evidence shall we. You have posted what you think is a bug on a forum not guaranteed to be monitored or even looked at occasionally by Keil staff. You then say that the people who have probably looked at what you wrote have got an incorrect attitude.
From this I can correctly conclude that you are an idiot.
Stop wasting our time. Goodbye.
Bighead, SHUT THE *** UP!
You need not to reply this thread like an idiot if you think it's wasting your time.
Thank you, Bradford! It's my mistake to post on the wrong forum.
