Hi everyone,
I have posted to this forum a couple months ago about using the enable_irq()/disable_irq() instruction intrinsics in RealView Compiler (ARMCC V4.0.0.728). In that occasion, I set up two software interrupts for calling such intrinsics, as they only have the intended effect when not in User Mode.
Just now, though, I realized that interrupts were not being disabled. I know for a fact that my SWI are set up appropriately, because they change the value of a flag I set up. Does anyone have any clue what could be happening? Documentation seems to be pretty clear about the fact that one enters supervisor mode during SWI, and that would be appropriate for enabling/disabling interrupts, but I must be missing something.
Relevant source code
void __SWI_8 (void) { __enable_irq(); __enable_fiq(); interrupts_enabled = 1; } void __SWI_9 (void) { __disable_irq(); __disable_fiq(); interrupts_enabled = 0; }
Relevant links
Instruction Intrinsics http://www.keil.com/support/man/docs/armcc/armcc_chdfgfab.htm
disable_irq() www.keil.com/.../armccref_CJAFBCBB.htm
enable_irq() www.keil.com/.../armccref_CJAEAEHA.htm
ARMCC: MODIFY IRQ FLAG TO ENABLE/DISABLE INTERRUPTS (RealView Compiler V3) http://www.keil.com/support/docs/3229.htm
Thanks in advance, -- George Andrew Brindeiro Robotron Automation and Technology
too long since i did this.
when you go into the swi, the processor switches to another dedicated CPSR. you changing irq and fiq change the CPSR of the swi.
when you leave swi the original cpsr gets restored. you disabling irq and fiq are only good in side the swi.
can be bad detail but consept is right.
always yo're freind.
Zeusti
ARM programmer and chef management engineer and desine consultant (retyred)
i never said Please read the manual but u can look at the hitex insiders guides. they r good.
www.hitex.co.uk/index.php
also look for the abi. real ARM experts know it.
Always yo're freind.
Zeusti.
zeusti@supercomputersforyouandyoremum.com
Zeusti,
Thanks for the reply, you have a good point.
I have read the hitex manuals, and was aware of the dedicated CPSR, but I guess I thought the intrinsics would change the CPSR in User Mode through the SPSR in Supervisor Mode.
I'll check if I can make it work by writing some inline assembly, and get back to this topic.
http://www.keil.com/support/man/docs/armcc/armcc_Chdgddcj.htm
Restrictions on inline assembly operations
Some low-level features that are available in the ARM assembler armasm, such as branching and writing to PC, are not supported.
Registers such as r0-r3, sp, lr, and the NZCV flags in the CPSR must be used with caution. If you use C or C++ expressions, these might be used as temporary registers and NZCV flags might be corrupted by the compiler when evaluating the expression. See Virtual registers.
The pc, lr, and sp registers cannot be explicitly read or modified using inline assembly code because there is no direct access to any physical registers. However, you can use the following intrinsics described in the Compiler Reference Guide to access these registers:
Hi John,
Thanks for the reply, but I did not directly access these registers.
Maybe you were confused by the second code section I posted... that is the assembly output of the compiler, not my code. Note that the code I posted in the first code section is commented out with semi-colons, and the corresponding assembly code follows.
Anyone else?
Sorry for my limited knowledge.
I did not notice this: http://www.keil.com/support/man/docs/armcc/armcc_Chdgbbia.htm There is no virtual Processor Status Register (PSR). Any references to the PSR are always to the physical PSR.
Hope my second try would be better. infocenter.arm.com/.../index.jsp Note that CPSR_c is used instead of CPSR in the MSR instruction, to avoid altering the condition code flags. A better implementation is:
/* NewState=1 will enable IRQ, NewState=0 will disable IRQ */ /* ARM core must be in a privileged mode, e.g. supervisor */ void ChangeIRQ(unsigned int NewState) { int my_cpsr; __asm { MRS my_cpsr, CPSR /* get current program status */ ORR my_cpsr, my_cpsr, #0x80 /* set IRQ disable bit flag */ BIC my_cpsr, my_cpsr, NewState, LSL #7 /* reset IRQ bit with new value */ MSR CPSR_c, my_cpsr /* store updated program status */ } }
which compiles into:
ChangeIRQ MRS r1,CPSR ORR r1,r1,#0x80 BIC r0,r1,r0,LSL #7 MSR CPSR_c,r0 MOV pc,lr
A corrected link to the mentioned code: infocenter.arm.com/.../index.jsp
I had to make some modifications to the code, but essentially it worked. For instance, that code assumes that the program is in Privileged Mode. In that case, I have to change the SPSR and not the CPSR, if I want interrupts to be enabled/disabled in User Mode.
I added that code with some modifications to my SWI code and the assembler output is consistent (the inline assembly part is showing in the code). Whenever I am able to test on the board, I'll post the final SWI code.
Thanks for the link! -- George Andrew Brindeiro Robotron Automation and Technology
