Hi everyone,
I created a C++ project and implemented some basic classes. The compilation works fine but in the linking process I get some errors. I don't really know what I do wrong. I assume someone familiar with using C++ and RealView can help.
Here are the error messages I get:
linking... .\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __aeabi_unwind_cpp_pr0 (referred from new.o). .\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __rt_new_handler_addr (referred from new.o). .\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol abort (referred from arm_exceptions_terminate.o). .\Obj\OrigaII_Test.axf: Error: L6218E: Undefined symbol __rt_eh_globals_addr (referred from arm_exceptions_globs.o). Target not created
Thank you, Frank
MicroLib is a highly-optimized library designed for deeply embedded applications written in C (C++ is not typically used in such applications).
Since MicroLib is optimized to use less code and data memory, there are some differences from the default C library.
Look at the following page for details: http://www.keil.com/arm/microlib.asp
... thank you for this information!
Frank
When i checked the Micro-Lib, it gives these problems:
linking... .\Temp\LPC2468IPB.axf: Error: L6218E: Undefined symbol __use_two_region_memory (referred from lpc2300.o). .\Temp\LPC2468IPB.axf: Error: L6218E: Undefined symbol __initial_sp (referred from entry.o). Target not created
Why?
Hi Philip,
did you implement these functions? If you use the standard Keil example code, these functions are located in the startup file.
Hi F D
My startup code is here: rapidshare.de/.../LPC2300.s.html
What i must to add in this startup code? Thanks for answer.
you should not publish third party source code files, it is legally not correct!
Here is a part of a startup-code that shows the parts of interest:
; Enter User Mode and set its Stack Pointer EXPORT __initial_sp ; Enter the C code ------------------------------------------------------------- IMPORT __main LDR R0, =__main BX R0 . . . ; User Initial Stack & Heap AREA |.text|, CODE, READONLY IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ENDIF
Take a look at other startup files in your code samples if you need more info. I hope this helps.
Hi F D Thanks for your opinion.
I added EXPORT __initial_sp only because i have other codes.
; Enter User Mode and set its Stack Pointer EXPORT __initial_sp ; <---- here MSR CPSR_c, #Mode_USR MOV SP, R0 SUB SL, SP, #USR_Stack_Size ; Enter the C code IMPORT __main LDR R0, =__main BX R0 ; User Initial Stack & Heap AREA |.text|, CODE, READONLY IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, = (Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR
But, the error message is:
assembling LPC2300.s... LPC2300.s(500): error: A1145E: Undefined exported symbol '__initial_sp'
The Micro-Lib option is checked.
What can i do?
Again take a look at the startup files provided in your RealView MDK installation (for example Keil\ARM\Startup\Philips\LPC2300.s).
Missing is the declaration for __initial_sp defined as:
AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE USR_Stack_Size __initial_sp SPACE ISR_Stack_Size
Thanks,
i used LPC2300.s 2006 version, i downloaded new version and the problem is solved.
Thank you very much again.
