How do I locate a constant variable at the end of code area using the Extended Linker ( LX51 ) ? In myfile source, my constant table is declared as: unsigned char code MyTable[10]= { ... } I would like to locate this constant table (by the corresponding segment at the end of my ROM). I use a Philips chip that provides 96kb of ROM mapped from 0x800000 to 0x817FFF. I use the ROM(HUGE) option in compiler and my application is not a banked one... I try with: - ?CO?myfile(0x817000), i have the L108 linker error - ?CO?myfile(^0x817FFF), i have the L108 linker error Could you help me?
In fact, i can use const far type by declaring my table in HCONST by the following way: const char far dummy[4]; With this, i find a ?FC?myfile segment in map file and i can locate it at the end of ROM....OK for this step! But, what about a table of functions declared as below in a source file: code void (void * TableOfFunctions[]) In the same way, i would like to locate also this table at the end of ROM? Can i consider this a table as CONSTANT table and could i move it in HCONST segment? Thank you for the application notes (160) that you send me!
