WHEN I COMPILE THIS CODE GIVEN BELOW IT GIVES ERRORS LIKE
error 52: Actual Argument type different from declaration 2 from type 'unsigned-char generic*' to type 'unsigned-char'
#include<8051.h> //--------------------------------------------------------------------------- #include "Kernel.h" #include "Task.h" #include "AVX.H"
extern xdata unsigned char taskRdyQue[64]; extern unsigned char taskRdyMatrixIndex; extern xdata unsigned char taskRdyMatrix[8] ;
unsigned char TaskCreate(TaskFunc pTaskFunc,unsigned char priority,unsigned char idata *InternalSP,unsigned char xdata *ExternalSP)
if (g_Kernel.TaskCount >= OS_TASK_COUNT) return 0;
#ifdef PREEMPTIVE
priority = 63 - priority ;
taskRdyMatrixIndex |= ( 1<< (priority >> 3) );
taskRdyMatrix[priority >> 3] |= ( 1<<(priority & 7) );
taskRdyQue[priority]=g_Kernel.TaskCount;
#endif
// Initialize the Task object. // Push low byte of pTaskFunc.
(unsigned char)*(IntSP) = (unsigned short)pTaskFunc; // Push high byte of pTaskFunc. *(IntSP + 1) = (unsigned short)pTaskFunc >> 8; // The size of all registers is 13 bytes.
g_Kernel.Tasks[g_Kernel.TaskCount].InternalSP =(IntSP + 0x0E) ; g_Kernel.Tasks[g_Kernel.TaskCount].ExternalSP = ExternalSP;
*(g_Kernel.Tasks[g_Kernel.TaskCount].ExternalSP) = *(IntSP);//*( InternalSP - 1); *(g_Kernel.Tasks[g_Kernel.TaskCount].ExternalSP + 1 ) = *(IntSP + 1);//*( InternalSP );
g_Kernel.TaskCount++;
return 1; } //--------------------------------------------------------------------------- ///* unsigned char TaskPrioritySet(unsigned char old_priority, unsigned char new_priority) {
if( new_priority>63 || new_priority<0 ) return 0;
old_priority = 63 - old_priority ; // convert pseudo priority
// check if any other bit is set if set then don't update task ready mat. index // reseting the bit which shows task is present
if( !( taskRdyMatrix[old_priority >> 3] &= (~( 1<<(old_priority & 7) ))) ) taskRdyMatrixIndex &= (~( 1<< (old_priority >> 3) ));
new_priority = 63 - new_priority ; // convert pseudo priority
taskRdyMatrixIndex |= ( 1<< (new_priority >> 3) ); //update with new value
//update task ready matrix table taskRdyMatrix[new_priority >> 3] |= ( 1<<(new_priority & 7) );
// update task ready queue with earlier tcb array index taskRdyQue[new_priority] = taskRdyQue[old_priority];
taskRdyQue[old_priority] = 0; // reset older tcb array index
TF0 = 1; // call context switcher
return 1; }
unsigned char TaskPend(unsigned char priority) {
if( priority>63 || priority<0 ) return 0;
priority = 63 - priority;
if( !( taskRdyMatrix[priority >> 3] &= (~( 1<<(priority & 7) ))) ) taskRdyMatrixIndex &= (~( 1<< (priority >> 3) ));
TF0 = 1; // call context switcher return 1;
unsigned char TaskResume(unsigned char priority) {
if( taskRdyQue[priority] ) // CHECK FOR TASK SIGNATURE {
taskRdyMatrixIndex |= ( 1<< (priority >> 3) ); //update with new value
return 1; } }
unsigned char TaskDelete(unsigned char priority) {
if( priority<63 && priority>=0 ) { priority = 63 - priority;
taskRdyQue[priority] = 0;
+++++____+++++++++++++__)))))))))))++++|||||||||||+++++
TASH.H FILE
//--------------------------------------------------------------------------- #ifndef TaskH #define TaskH //--------------------------------------------------------------------------- // Task function pointer.
#define PREEMPTIVE
typedef void (code *TaskFunc)();
typedef struct _Task { unsigned char idata *InternalSP; // Internal stack pointer. unsigned char xdata * ExternalSP; // External stack pointer(for reentrant function). } Task;
// Create a Task object. // Parameter: // pTaskFunc: The Task function pointer. // InternalSP: Internal stack pointer. // ExternalSP: External stack pointer. // Return value: // 0: Error. // 1: Success. unsigned char TaskCreate(TaskFunc pTaskFunc,unsigned char priority,unsigned char idata *InternalSP;unsigned char xdata *ExternalSP); unsigned char taskPrioritySet(unsigned char old_priority, unsigned char new_priority); unsigned char tickRateSet(unsigned char milli_sec); unsigned char taskDelete(unsigned char priority);
//--------------------------------------------------------------------------- #endif // ThreadH //---------------------------------------------------------------------------
