Hi, I have been working on a project which requires interfacing a keypad and a LCD to 8051 microcontroller using keil software(microvision version 5). I have difficulty resolving a C202 error, error statement being ‘PIN_Dx’: undefined identifier. (x being 0,1,2,3,4,5,6,7) I have attached the source code below. Please help
#include <reg51.h> #include <string.h> #define lcd_4bit P1 #define keypad P2 char u1[]="0001",U2[]="0002",U3[]="0003",p[10],k,v1[10]; void lcd_init(); void lcd_cmd(unsigned char b); void lcd_str(unsigned char a); void gotoxy(int x,int y); void lcd_clear(); void lcd_array(char *a); int i=0,d1,d2,d3,z1=1,z2=1,z3=1; int key(); int key() { while(1) { output_low(PIN_D4); output_high(PIN_D5); output_high(PIN_D6); output_high(PIN_D7); if(input(PIN_D0)==0) { while(input(PIN_D0)==0); return('7'); goto k; } else if(input(PIN_D1)==0) { while(input(PIN_D1)==0); return('4'); goto k; } else if(input(PIN_D2)==0) { while(input(PIN_D2)==0); return('1'); goto k; } else if(input(PIN_D3)==0) { while(input(PIN_D3)==0); return('c'); goto k; } output_high(PIN_D4); output_low(PIN_D5); output_high(PIN_D6); output_high(PIN_D7); if(input(PIN_D0)==0) { while(input(PIN_D0)==0); return('8'); goto k; } else if(input(PIN_D1)==0) { while(input(PIN_D1)==0); return('5'); goto k; } else if(input(PIN_D2)==0) { while(input(PIN_D2)==0); return('2'); goto k; } else if(input(PIN_D3)==0) { while(input(PIN_D3)==0); return('0'); goto k; } output_high(PIN_D4); output_high(PIN_D5); output_low(PIN_D6); output_high(PIN_D7); if(input(PIN_D0)==0) { while(input(PIN_D0)==0); return('9'); goto k; } else if(input(PIN_D1)==0) { while(input(PIN_D1)==0); return('6'); goto k; } else if(input(PIN_D2)==0) { while(input(PIN_D2)==0); return('3'); goto k; } else if(input(PIN_D3)==0) { while(input(PIN_D3)==0); return('='); goto k; } output_high(PIN_D4); output_high(PIN_D5); output_high(PIN_D6); output_low(PIN_D7); if(input(PIN_D0)==0) { while(input(PIN_D0)==0); return('/'); goto k; } else if(input(PIN_D1)==0) { while(input(PIN_D1)==0); return('*'); goto k; } else if(input(PIN_D2)==0) { while(input(PIN_D2)==0); return('-'); goto k; } else if(input(PIN_D3)==0) { while(input(PIN_D3)==0); return('+'); goto k; } } k: delay_ms(1); } void lcd_init(); void lcd_cmd(unsigned char b); void lcd_str(unsigned char a); void gotoxy(int x,int y); void lcd_clear(); void lcd_array(char *a); void lcd_init() { lcd_cmd(0x02); lcd_cmd(0x28); lcd_cmd(0x0c); lcd_cmd(0x06); lcd_cmd(0x80); } void lcd_cmd(unsigned char b) { int b1; b1 = (b & 0xF0); output_b(b1); output_high(PIN_B2); delay_ms(1); output_low(PIN_B2); b1 = ((b<<4) & 0xF0); output_b(b1); output_high(PIN_B2); delay_ms(1); output_low(PIN_B2); } void lcd_str(unsigned char a) { int a1; a1=(a&0xF0); output_b(a1 | 0x01); output_high(PIN_B2); delay_ms(1); output_low(PIN_B2); a1=((a<<4)&0xF0); output_b(a1 | 0x01); output_high(PIN_B2); delay_ms(1); output_low(PIN_B2); } void gotoxy(int x,int y) { if(y==0) { lcd_cmd(0x80+x); } else if(y==1) { lcd_cmd(0xc0+x); } } void lcd_clear() { lcd_cmd(0x01); lcd_cmd(0x80); } void lcd_array(char *a) { while(*a) { lcd_str(*a++); } } char u1[]="1234",U2[]="9876",p[10],k,v1[10]; int i=0,d1,d2,z1=1,z2=1; void main() { char m[30]; lcd_init(); lcd_str("Password Based"); gotoxy(0,1); lcd_str("Circuit Breaker"); delay_ms(1500); l1: lcd_clear(); lcd_str("Enter Password:"); gotoxy(0,1); while(1) { k=key(); if(k=='c') { lcd_clear(); gotoxy(0,0); lcd_str("Enter Password:"); gotoxy(0,1); i=0; } else if(k=='=') { p[i]='\0'; goto l; } else { lcd_str(k); p[i]=k; i++; } } l: gotoxy(0,1); d1=strcmp(u1,p); d2=strcmp(u2,p); if(d1==0) { gotoxy(0,0); lcd_str("Correct Password"); gotoxy(0,1); if(z1==1) { output_bit(PIN_C0,1); lcd_str("Load 1 Active"); delay_ms(300); z1==0; goto l1; } else if(z1==0) { output_bit(PIN_C0,0); lcd_str("Load 1 Inactive"); delay_ms(300); z1==1; goto l1; } } else if(d2==0) { gotoxy(0,0); lcd_str("Correct Password"); gotoxy(0,1); if(z2==1) { output_bit(PIN_C1,1); lcd_str("Load 2 Active"); delay_ms(300); z2==0; goto l1; } else if(z2==0) { output_bit(PIN_C1,0); lcd_str("Load 2 Inactive"); delay_ms(300); z2==1; goto l1; } } else { lcd_clear(); lcd_str("Wrong Password"); delay_ms(300); goto l1; } }
Where have you put the #define ? I can't see any evidance of them their in you're code.
I have given #define right at the beginning of the code along with the header files. Since, the D pin sequence is the input pin sequence on the LCD connected directly to Port 1 of the 8051 micro controller, i have given that as #define lcd_4bit P1. Considering #define must have micro controller entities and not the external peripheral's. Kindly, do check again and let me know if there are any other fundamental mistakes.
Where do you #define PIN_D4 and the others???
You say the compiler is complaining about them. I can't see them. But you say you define them. Who do we believe?
I think the compiler knows what it is doing..
Perhaps improve the structure of the code so the routines aren't huge and repetitive, and goto is avoided.
Please see previous Help: http://www.keil.com/forum/63979/
Why start a new thread?
As noted there, the complete compiler message includes the exact location - file & line number - at which the error was detected.
Your post doesn't show line numbers, so it's up to you to show where the error is being reported.
The second rule of resolving error reports is to just read the text literally:
Your message clearly tells you the problem - that something is un-defined.
So the answer is to define that thing!
This is why the others are asking you where (you think) that definition is - it is certainly not visible in the code you have posted.
