resolving C202 error
Hi, I have been working on a project which requires interfacing a keypad and a LCD to 8051 microcontroller using keil software(microvision version 5). I have difficulty resolving a C202 error, error statement being ‘PIN_Dx’: undefined identifier. (x being 0,1,2,3,4,5,6,7)
I have attached the source code below. Please help
#include <reg51.h>
#include <string.h>
#define lcd_4bit P1
#define keypad P2
char u1[]="0001",U2[]="0002",U3[]="0003",p[10],k,v1[10];
void lcd_init();
void lcd_cmd(unsigned char b);
void lcd_str(unsigned char a);
void gotoxy(int x,int y);
void lcd_clear();
void lcd_array(char *a);
int i=0,d1,d2,d3,z1=1,z2=1,z3=1;
int key();
int key()
while(1)
     output_low(PIN_D4);
     output_high(PIN_D5);
     output_high(PIN_D6);
     output_high(PIN_D7);
     if(input(PIN_D0)==0)
     while(input(PIN_D0)==0);
     return('7');
     goto k;
     else if(input(PIN_D1)==0)
    while(input(PIN_D1)==0);
     return('4');
     goto k;
     else if(input(PIN_D2)==0)
       while(input(PIN_D2)==0);
     return('1');
      goto k;
     else if(input(PIN_D3)==0)
       while(input(PIN_D3)==0);
     return('c');
    goto k;
     output_high(PIN_D4);
     output_low(PIN_D5);
     return('8');
      goto k;
     return('5');
      goto k;
     return('2');
      goto k;
     return('0');
      goto k;
     output_low(PIN_D6);
     return('9');
      goto k;
     return('6');
      goto k;
     return('3');
     goto k;
     return('=');
     goto k;
     output_low(PIN_D7);
     return('/');
    goto k;
     return('*');
     goto k;
     return('-');
     goto k;
     return('+');
    goto k;
   k:
   delay_ms(1);
void lcd_init();
void lcd_clear();
void lcd_init()
lcd_cmd(0x02);
lcd_cmd(0x28);
lcd_cmd(0x0c);
lcd_cmd(0x06);
lcd_cmd(0x80);
int b1;
b1 = (b & 0xF0);
output_b(b1);
 output_high(PIN_B2);
delay_ms(1);
output_low(PIN_B2);
b1 = ((b<<4) & 0xF0);
output_b(b1);
delay_ms(1);
output_low(PIN_B2);
int a1;
a1=(a&0xF0);
output_b(a1 | 0x01);
delay_ms(1);
output_low(PIN_B2);
a1=((a<<4)&0xF0);
delay_ms(1);
output_low(PIN_B2);
if(y==0)
lcd_cmd(0x80+x);
else if(y==1)
lcd_cmd(0xc0+x);
void lcd_clear()
lcd_cmd(0x01);
lcd_cmd(0x80);
while(*a)
lcd_str(*a++);
char u1[]="1234",U2[]="9876",p[10],k,v1[10];
int i=0,d1,d2,z1=1,z2=1;
void main()
char m[30];
lcd_init();
 lcd_str("Password Based");
    gotoxy(0,1);
    lcd_str("Circuit Breaker");
    delay_ms(1500);
l1:
    lcd_clear();
    lcd_str("Enter Password:");
    gotoxy(0,1);
   while(1)
    k=key();
    if(k=='c')
    lcd_clear();
    gotoxy(0,0);
    gotoxy(0,1);
    i=0;
    else if(k=='=')
    p[i]='\0';
    goto l;
    else
    lcd_str(k);
    p[i]=k;
    i++;
   l:
   gotoxy(0,1);
   d1=strcmp(u1,p);
   d2=strcmp(u2,p);
   if(d1==0)
   gotoxy(0,0);
   lcd_str("Correct Password");
   gotoxy(0,1);
   if(z1==1)
   output_bit(PIN_C0,1);
   lcd_str("Load 1 Active");
   delay_ms(300);
   z1==0;
   goto l1;
   else if(z1==0)
   output_bit(PIN_C0,0);
   lcd_str("Load 1 Inactive");
   delay_ms(300);
   z1==1;
   goto l1;
  else if(d2==0)
   gotoxy(0,0);
   gotoxy(0,1);
  if(z2==1)
   output_bit(PIN_C1,1);
   lcd_str("Load 2 Active");
   delay_ms(300);
   z2==0;
   goto l1;
   else if(z2==0)
   output_bit(PIN_C1,0);
   lcd_str("Load 2 Inactive");
   delay_ms(300);
   z2==1;
   goto l1;
 else
 lcd_clear();
 lcd_str("Wrong Password");
 delay_ms(300);
 goto l1;
