hi, am using keil mdk5.26 to build c and c++ files and when i enclude <iostream> in header files that contain classes and cpp features it gives me 19 error as followas:
*** Using Compiler 'V6.10.1', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin' Build target 'Target 1' Application/SysMng.c(4): warning: In file included from... ./decentlib/src\elkrem.h(13): warning: In file included from... ./decentlib/src/Arduhdlc.h(12): warning: In file included from... C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iostream(38): warning: In file included from... C:/Keil_v5/ARM/ARMCLANG/include/libcxx\ios(215): warning: In file included from... C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(96): error: unknown type name '_LIBCPP_BEGIN_NAMESPACE_STD' _LIBCPP_BEGIN_NAMESPACE_STD ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(98): error: expected ';' after top level declarator class _LIBCPP_TYPE_VIS ios_base; ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(100): error: unknown type name 'template' template<class _CharT> struct _LIBCPP_TEMPLATE_VIS char_traits; ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(100): error: expected identifier or '(' template<class _CharT> struct _LIBCPP_TEMPLATE_VIS char_traits; ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(101): error: unknown type name 'template' template<class _Tp> class _LIBCPP_TEMPLATE_VIS allocator; ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(101): error: expected identifier or '(' template<class _Tp> class _LIBCPP_TEMPLATE_VIS allocator; ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(103): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(103): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(106): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(106): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(108): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(108): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(110): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(110): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(112): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(112): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT> > ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(115): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT>, ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(115): error: expected identifier or '(' template <class _CharT, class _Traits = char_traits<_CharT>, ^ C:/Keil_v5/ARM/ARMCLANG/include/libcxx\iosfwd(118): error: unknown type name 'template' template <class _CharT, class _Traits = char_traits<_CharT>, ^ fatal error: too many errors emitted, stopping now [-ferror-limit=] 20 errors generated. compiling SysMng.c... ".\Objects\ELKREM.axf" - 19 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:03
## what should i do
You have configured it to compile as C++ (not just 'C') - haven't you?
am using compiler v6.10.1 to enable c++ 11 features
You still have to tell it whether you want it to compile as C or C++
By default, it will compile a file .c extension as C - not C++
i managed to solve the problem using extern c in cpp files but there is another problem that crash the debugging and it doesn't run to main !!
linking... .\Objects\ELKREM.axf: Warning: L6776W: The debug frame in .debug_frame(spark_wiring_string.o) does not describe an executable section. Program Size: Code=230416 RO-data=58212 RW-data=1944 ZI-data=88032
can you help me , thanks in advance
so start another thread!
You can always provide a link back to this one, for reference.
And provide a link here
So you couldn't be bothered, then? http://www.keil.com/forum/63946
Hello Islam,
Posting this information on this thread too, so it is easier to find.
As for the Linker Warning L6776W, it is safe to ignore. You can read more about it here:
http://www.keil.com/support/docs/4097.htm
