Hello, I just created a project with stm32cubeMX, after generating my code and importer on Keil, I can not compile while I did not even write my code and the STM32L011 to 8K of RAM normally. Thanks a lot for your help.
Create a project with STM32CubeMX https://ibb.co/mP4aWF https://ibb.co/kA4ndv https://ibb.co/iGsvWF
The Error: L6406E: No space in execution regions with .ANY selector matching stm32l0xx_hal.o(i.HAL_GetTick). Error: L6407E: Sections of aggregate size 0x70 bytes could not fit into .ANY selector(s).
https://ibb.co/hGgprF https://ibb.co/cmHvWF
Configuration to Keil https://ibb.co/iTRYJv https://ibb.co/gGVtJv https://ibb.co/k9WNBF
Thank you :).
Keil tools don't compile images. It would take a lot of effort to replicate, consider ZIPing up a complete project demonstrating the failure. Consider if the compiled code will fit in the device, and that the correct target and memory mapping has been selected.
Hello, I did not really understand what you mean, I go over every time 2K RAM memory and flash 8K. Thank you.
