Adding MDK Network Component causes Linker errors
LPC1788 project (512K Flash)
I did some testing on the KEIL MDKARM network components. Only TCP and UDP Sockets were used, no other services required. A small 40K project was tested on the embedded artist lpc1788 eval board. Once I was happy with the code, I proceeded to move it over to my main project.
Adding the Network Core Library to my project causes the linker to claim all of my *.o files in the project not to have space. See below.
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching stdio_streams.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching streamlock.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching tokenparse.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching GUI_Core.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching SCROLLBAR.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching WM.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching fs_mapi.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching GUIDEV_StaticDevices.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching hal_cm.o(.data).
.\Flash\Blinky.axf: Error: L6406E: No space in execution regions with .ANY selector matching fs_common.o(.data).
.\Flash\Blinky.axf: Error: L6407E: Sections of aggregate size 0x2d0 bytes could not fit into .ANY selector(s).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 74 error messages.
Here is the map file of the project before I added the network library:
      Code (inc. data)   RO Data    RW Data    ZI Data      Debug   Library Name
     15788        394       1212          2          0       9480   FS_LFN_CM3_L.lib
      5758        598          0         37        100      82726   RTX_CM3.lib
      6982        260        289         16        348       6464   c_w.l
    112242       1598      67138        788       1592      48896   emWin_522_Keil460_M3_LE.lib
      4254        292          0          0          0       2344   fz_ws.l
       148          6          0          0          0        116   m_ws.l
    145312       3148      68648        856       2044     150026   Library Totals
    220132       9498      83364       8548   13399148     521462   Grand Totals
    220132       9498      83364       2040   13399148     521462   ELF Image Totals (compressed)
    220132       9498      83364       2040          0          0   ROM Totals
    Total RO  Size (Code + RO Data)               303496 ( 296.38kB)
    Total RW  Size (RW Data + ZI Data)          13407696 (13093.45kB)
    Total ROM Size (Code + RO Data + RW Data)     305536 ( 298.38kB)
Total ROM size is 512K, and I have used 300K of it.
The network library is not that large, less than 40K, so I have wnough memory.
Here is my Linker Scatter File used for project:
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000 0x00080000  {    ; load region size_region
  ER_IROM1 0x00000000 0x00080000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x10000000 0x00010000  {  ; RW data
   .ANY (+RW +ZI)
  RW_RAM1 0xA0000000 UNINIT 0x02000000  {  ; RW data
   * (VRAM, GUI_RAM, GUIDEMO_STACK, FS_RAM, IP_RAM, USB_RAM, TICKET_RAM)
   .ANY (HEAP) ; set the heap here
Any suggestions would be apreciated.
Jan.
