I am interfacing GSM with ARM LPC2148
I am interfacing GSM module with ARM LPC 2148 , when i compiled code in KEIL 4 i am getting these errors please help me .
#define CR 0x0D
#include <LPC214X.H>
#include <stdio.h>
void getstring(unsigned char *);
int getchar (void) /* Read character from Serial Port */
void status_ok(void);
void Serial_Init(void);
void delay(unsigned int n);
void main(void)
{ unsigned int cnt=0x80,m; char xx; Serial_Init(); elay(50); while(1) { printf("AT\r"); // AT COMMAND FOR INITIALING status_ok(); printf("AT+IPR=9600\r"); // AT COMMAND FOR BAUD RATE status_ok(); printf("AT+CMGR=2\r"); // Reading the message detail // at Index 1 with phone number, data and time status_ok(); delay(250); printf("ATD9790550124;\r");//AT COMMAND FOR CALL DIALING delay(250); status_ok(); delay(500); delay(500); delay(500); delay(500); delay(500); delay(500); printf("ATH\r"); // AT COMMAND FOR CALL DISCONNECTING delay(250); status_ok(); delay(500); printf("ATDL\r"); // AT COMMAND FOR REDIALING delay(250); status_ok(); delay(500); delay(500); delay(500); printf("ATH\r"); // AT COMMAND FOR ANSWERING THE CALL delay(250); status_ok(); delay(500); delay(500); } }
void getstring(unsigned char *array) { unsigned char temp=0, i=0; do { temp = getchar(); *array++ = temp; } while((temp != '\r') && (temp != '\n')); *array = '\0';
{ while (!(U0LSR & 0x01)); return (U0RBR); }
} void status_ok(void)
{ getstring(y); while(!(strstr(y,"OK"))) getstring(y); pointr = strstr(y,"OK"); lcd_cmd(0xc0); lcd_data(*pointr++); lcd_data(*pointr); delay(500); lcd_cmd(0x01);
} void Serial_Init(void)
{ PINSEL0 |= 0X00000005; //Enable Txd0 and Rxd0 U0LCR = 0x00000083; //8-bit data, no parity, 1-stop bit U0DLL = 0x00000061; //for Baud rate=9600,DLL=82 U0LCR = 0x00000003; //DLAB = 0;
} void delay(unsigned int n)
{ unsigned int i,j; for(i=0;i<n;i++) { for(j=0;j<12000;j++) {;} } }
compiling gsm.c...
gsm.c(5): error: #55: too many arguments in macro invocation
gsm.c(5): error: #79: expected a type specifier
gsm.c(5): error: #141-D: unnamed prototyped parameters not allowed when body is present
gsm.c(6): error: #130: expected a "{"
gsm.c(10): warning: #12-D: parsing restarts here after previous syntax error
gsm.c(13): warning: #223-D: function "Serial_Init" declared implicitly
gsm.c(14): warning: #223-D: function "elay" declared implicitly
gsm.c(20): warning: #223-D: function "delay" declared implicitly
gsm.c(22): warning: #223-D: function "status_ok" declared implicitly
gsm.c(11): warning: #177-D: variable "cnt" was declared but never referenced
gsm.c(11): warning: #177-D: variable "m" was declared but never referenced
gsm.c(12): warning: #177-D: variable "xx" was declared but never referenced
gsm.c(57): error: #268: declaration may not appear after executable statement in block
gsm.c(49): warning: #177-D: variable "i" was declared but never referenced
gsm.c(57): error: #67: expected a "}"
gsm.c(57): error: #55: too many arguments in macro invocation
gsm.c(57): error: #79: expected a type specifier
gsm.c(57): error: #247: function "getc" has already been defined
gsm.c(57): error: #141-D: unnamed prototyped parameters not allowed when body is present
gsm.c(62): error: #169: expected a declaration
gsm.c(89): warning: #1-D: last line of file ends without a newline
gsm.c(89): warning: At end of source: #12-D: parsing restarts here after previous syntax error
gsm.c - 11 Error(s), 11 Warning(s).
