#include <reg51.h> sbit Read = P2^5; sbit Write = P2^6; sbit INTR = P2^7; //#define MYDATA = P1; sfr MYDATA = 0x80; void ConvertAndDispaly(unsigned char value); void MSDelay(unsigned int value); int value; void main () { MYDATA = 0xFF; INTR = 1; Read=1; Write =1; while (1) { Write = 0; Write = 1; while (INTR ==1); Read = 0; value = MYDATA; ConvertAndDisplay(value); Read = 1; } } void ConvertAndDisplay(unsigned char value) // { unsigned char x, d1,d2,d3; x=value/10; d1=value%10; d2=x%10 ; d3=x/10; P0=d1; MSDelay(250); P0=d2; MSDelay(250); P0=d3; MSDelay(250); // } void MSDelay(unsigned int value) { // unsigned char i,j; unsigned int i,j; for(i=0;i<=value;i++) for(j=0;j<=1275;j++) } </prev> the following error occurs, please help me out with this. Build target 'Target 1' compiling temp.c... TEMP.C(24): warning C206: 'ConvertAndDisplay': missing function-prototype TEMP.C(24): error C267: 'ConvertAndDisplay': requires ANSI-style prototype TEMP.C(31): error C132: 'x': not in formal parameter list TEMP.C(31): error C132: 'd1': not in formal parameter list TEMP.C(31): error C132: 'd2': not in formal parameter list TEMP.C(31): error C132: 'd3': not in formal parameter list TEMP.C(32): error C244: 'x': can't initialize, bad type or class TEMP.C(32): error C132: 'x': not in formal parameter list TEMP.C(33): error C244: 'd1': can't initialize, bad type or class TEMP.C(33): error C132: 'd1': not in formal parameter list TEMP.C(34): error C244: 'd2': can't initialize, bad type or class TEMP.C(34): error C202: 'x': undefined identifier TEMP.C(34): error C132: 'd2': not in formal parameter list TEMP.C(35): error C244: 'd3': can't initialize, bad type or class TEMP.C(35): error C202: 'x': undefined identifier TEMP.C(35): error C132: 'd3': not in formal parameter list TEMP.C(36): error C244: 'P0': can't initialize, bad type or class TEMP.C(36): error C202: 'd1': undefined identifier TEMP.C(36): error C132: 'P0': not in formal parameter list TEMP.C(37): error C141: syntax error near '250' TEMP.C(37): error C132: 'MSDelay': not in formal parameter list TEMP.C(38): error C244: 'P0': can't initialize, bad type or class TEMP.C(38): error C202: 'd2': undefined identifier TEMP.C(38): error C132: 'P0': not in formal parameter list TEMP.C(39): error C141: syntax error near '250' TEMP.C(39): error C132: 'MSDelay': not in formal parameter list TEMP.C(40): error C244: 'P0': can't initialize, bad type or class TEMP.C(40): error C202: 'd3': undefined identifier TEMP.C(40): error C132: 'P0': not in formal parameter list TEMP.C(41): error C141: syntax error near '250' TEMP.C(41): error C132: 'MSDelay': not in formal parameter list TEMP.C(46): error C132: '_MSDelay': not in formal parameter list TEMP.C(46): error C141: syntax error near '{' TEMP.C(48): error C136: 'i': 'void' on variable TEMP.C(48): error C132: 'i': not in formal parameter list TEMP.C(48): error C136: 'j': 'void' on variable TEMP.C(48): error C132: 'j': not in formal parameter list TEMP.C(49): error C141: syntax error near 'for' TEMP.C(49): error C141: syntax error near '=', expected ')' TEMP.C(49): error C129: missing ';' before '<=' Target not created
