Create Software Pack
Have anyone tried to make The steps from tutorial keil.com/.../_c_p__s_w_components.html ?
When I run gen_pack.bat, I get the following:
PackChk.exe 1.0.0 (9/4/2014)
Copyright (C) 2014 ARM Ltd.
Checking Package Description
Reading PDSC File. DONE
. Verifying.
Checking Pack information..... DONE
. Checking Pack content
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 8) Filename mismatch (case sensitive): PDSC name : 'Docs\license.txt' Filename : 'Docs\license'
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 55) Filename mismatch (case sensitive): PDSC name : 'Docs\MySWComp.htm' Filename : 'Docs\MySWComp'
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 56) Filename mismatch (case sensitive): PDSC name : 'MySWComp\header_mylib.h' Filename : 'MySWComp\header_mylib'
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 57) Filename mismatch (case sensitive): PDSC name : 'MySWComp\config_mylib.h' Filename : 'MySWComp\config_mylib'
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 58) Filename mismatch (case sensitive): PDSC name : 'MySWComp\mylib_one.c' Filename : 'MySWComp\mylib_one'
*** ERROR M310: .\Files\MyVendor.MyPack.pdsc (Line 59) Filename mismatch (case sensitive): PDSC name : 'MySWComp\mylib_two.c' Filename : 'MySWComp\mylib_two'
Checking Package Description FAILED!
Found 6 Error(s) and 0 Warning(s).
