Friend, I want to modify the HTTP Server Error pages , I copy the module HTTP_err.c to my project .When I try to compile the project,I get the following errors:
linking... .\out\2188pro.axf: Error: L6200E: Symbol http_err_401 multiply defined (by http_err.o and http_err.o). .\out\2188pro.axf: Error: L6200E: Symbol http_err_404 multiply defined (by http_err.o and http_err.o). .\out\2188pro.axf: Error: L6200E: Symbol http_err_501 multiply defined (by http_err.o and http_err.o). .\out\2188pro.axf: Error: L6200E: Symbol http_err_head multiply defined (by http_err.o and http_err.o). .\out\2188pro.axf: Error: L6200E: Symbol http_err_foot multiply defined (by http_err.o and http_err.o). Target not created
Ideas?
Thanks lx
Same to me, any idea....
You are using outdated HTTP_err.c overlay file. Please use the latest from MDK4.50 found in ..\Keil\ARM\RL\TCPnet\User\HTTP_err.c
The item http_err_403 is missing, and the linker picks also the default internal HTTP_err module from the library. Then it finds some symbols duplicated.
hi,Franc Thanks for replying.You are right. Now it's working fine.
