I am getting error like this...program is running fine,when all file made to one main file..bt problem while creating different file....can some one suggest,how to clear this. linking... *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: LCD_INIT MODULE: lcd.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _LCD_STR MODULE: lcd.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _LCD_CMD MODULE: lcd.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _LCD_DATA MODULE: lcd.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _DELAY MODULE: lcd.obj (LCD) *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_LCD_STR?LCD *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?LCD_INIT?LCD Program Size: data=15.0 xdata=0 code=652
Sounds almost identically the same as: http://www.keil.com/forum/21436/
So - do we have a whole class of students asking questions about the same problem? Or a person using multiple aliases?
thanks fr ur reply..ya he is my friend, we are doing same project in our college....that's why...dan u plz suggest what is the exact thing we have to change....i have tried with extern in header file also,bt it's not working...
So why don't you work together - instead of just duplicating each other's work??
Maybe the Professor said Not to and they listened?
This is my complete code:- suggest me plz...i thought i am good enough in c...bt still i am lagging in that....i will be thankful to u sir
MAIN.C:- #include <REGX51.H> #include"SERIAL.c" #include"LCD.c"
sbit rf=P2^0; sbit motor=P0^0;
unsigned char asc,ok[2],r[4],a,i,oxoa, a,m[20],j,temp[10],temp1[10];
\*prototypes*/ void cmdwrt_lcd(unsigned char cmd); void serial_transmit(unsigned char *srstr); void command(unsigned char d[]); void serial_tx(unsigned char srda); void delay1();
void gsm_send() { command("AT"); delay1(); command("AT+CMGF=1"); delay(65000); delay(65000); serial_transmit("AT+CMGS="); serial_tx('"'); serial_transmit("9710362655"); serial_tx('"'); serial_tx(0x0d); serial_tx(0x0a); delay(65000); delay(65000); delay(65000); delay(65000); serial_transmit("Vehicle Thefted "); serial_tx(0x0a); serial_transmit("Send Stop message to stop the vehicle"); serial_tx(0x0a); delay(650); serial_tx(0x1A); delay(65000); delay(65000); delay(65000); delay(65000); } void gsm_send1() { command("AT"); delay1(); command("AT+CMGF=1"); delay(65000); delay(65000); serial_transmit("AT+CMGS="); serial_tx('"'); serial_transmit("9710362655"); serial_tx('"'); serial_tx(0x0d); serial_tx(0x0a); delay(65000); delay(65000); delay(65000); delay(65000); serial_transmit("Your Vehicle has been stopped"); serial_tx(0x0a); delay(650); serial_tx(0x1A); delay(65000); delay(65000); delay(65000); delay(65000); }
void wait_0x0a() { do { a=serial_rx(); }while(a!=0x0a); } void rec_msg() { //recevingmessage unsigned char i=0; do
{ while(RI==0); temp[i]=SBUF; i++; RI=0; } while(temp[i-1]!=0x0A); } void check_ok() { unsigned char i; for(i=0;i<=3;i++) //receving OK// { while(RI==0); temp1[i]=SBUF; RI=0; } } void command(unsigned char d[]) { serial_transmit(&d[0]); cmdwrt_lcd(0x80); //display_lcd(&d[0]); serial_tx(0x0d); wait_0x0a(); check_ok(); temp1[2]='\0'; delay(65000); delay(65000); cmdwrt_lcd(0xc0); } void delay1() { delay(65000);delay(65000);delay(65000); } void gsm_read() { command("AT"); delay1(); command("AT+CMGF=1"); delay1(); command("AT+CGSMS=1"); delay1(); command("AT+CMGD=1"); delay1(); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); display_lcd("Waiting for Msg"); for(j=0;j<=15;j++) { while(RI==0); //recevingmessage m[j]=SBUF; RI=0; } delay1(); cmdwrt_lcd(0xC0); display_lcd(&m[0]); delay1(); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); serial_transmit("AT+CMGR=1"); display_lcd("AT+CMGR=1"); serial_tx(0x0d); wait_0x0a(); wait_0x0a(); wait_0x0a(); rec_msg(); delay1(); temp[4]='\0'; cmdwrt_lcd(0xc0); display_lcd(&temp[0]); delay1(); delay1(); if(temp[0]=='S'&& temp[1]=='t'&&temp[2]=='o'&&temp[3]=='p') { motor=0; cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); display_lcd("Vehicle Stopped"); gsm_send1();
} void main() { serial_init(); lcd_init(); P0=0x00; display_lcd("VEHI.THEFT ALERT"); cmdwrt_lcd(0xC0); display_lcd("SYSTEM USING GSM"); motor=1; delay(65000); delay(65000); delay(65000); delay(65000); while(1) { if(rf==0) { cmdwrt_lcd(0x01); display_lcd(" VEHICLE THEFTED"); gsm_send(); gsm_read(); while(rf==0); } } }
lcd.c:-
include <REGX51.H>
sbit rs = P3^5; sbit rw = P3^6; sbit en = P3^7;
void delay(unsigned int dela) { unsigned int i; for(i=0;i<dela;i++); }
void cmdwrt_lcd(unsigned char cmd) { P1 = cmd; rs = 0; rw = 0; en = 1; delay(15); en = 0; delay(150); }
void datawrt_lcd(unsigned char datas) { P1 = datas; rs = 1; rw = 0; en = 1; delay(15); en = 0; delay(150); }
void display_lcd(unsigned char *lcdstr) { while (*lcdstr !='\0') { datawrt_lcd(*lcdstr); lcdstr++; } }
void lcd_init() { cmdwrt_lcd(0x38); cmdwrt_lcd(0x0C); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); }
SERAIL.c:-
#include <REGX51.H>
#include"header.h" //void datawrt_lcd(unsigned char datas);
void serial_init() { TMOD = 0x20; TH1 = 0xFD; SCON = 0x50; TR1 = 1; }
void serial_tx(unsigned char srda) { SBUF = srda; while(TI == 0); TI = 0; }
void serial_transmit(unsigned char *srstr) { while(*srstr != '\0') { serial_tx(*srstr); //datawrt_lcd(*srstr); srstr++; } }
unsigned char serial_rx() { unsigned char rbuf; while(RI == 0); RI = 0; rbuf = SBUF; return rbuf; }
HEADER.h:-
#ifndef HEADER_H #define HEADER_H
extern void serial_tx(unsigned char); extern void serial_transmit(unsigned char *); extern unsigned char serial_rx(); extern void serial_init(); extern void lcd_init(); extern void display_lcd(unsigned char *); extern void datawrt_lcd(unsigned char); extern void cmdwrt_lcd(unsigned char); extern void delay(unsigned int);
#endif
getting error as linking... *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: SERIAL_RX MODULE: SERIAL.obj (SERIAL) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _SERIAL_TRANSMIT MODULE: SERIAL.obj (SERIAL) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _SERIAL_TX MODULE: SERIAL.obj (SERIAL) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: SERIAL_INIT MODULE: SERIAL.obj (SERIAL) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: LCD_INIT MODULE: LCD.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _DISPLAY_LCD MODULE: LCD.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _DATAWRT_LCD MODULE: LCD.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _CMDWRT_LCD MODULE: LCD.obj (LCD) *** ERROR L104: MULTIPLE PUBLIC DEFINITIONS SYMBOL: _DELAY MODULE: LCD.obj (LCD) *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?SERIAL_INIT?SERIAL *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_SERIAL_TRANSMIT?SERIAL *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?SERIAL_RX?SERIAL *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_DISPLAY_LCD?LCD *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?LCD_INIT?LCD Program Size: data=60.0 xdata=0 code=1087
can any body suggest me plz..by seeing above code......i have pinched my head last n8....bt i did,t gt the answer.
Interesting - you have managed to get the compiler to accept
\*prototypes*/
as a valid C comment?
Another interesting thing - you never noticed the rules about how to post source code on this site? Don't you think your posted code looks very, very strange, with line breaks at very unexpected places? Didn't you start to figure out what was wrong with the strange look when you saw it?
A third interesting thing - how will we be able to know if you have included the same C file twice in your project?
that i did't mentioned in code..that i have mentioned for your reference sir....i am new to this website..when i used to copy the code means it seems good..bt while i post in tht...it appers like tht...i hope this is some wat readable...
MAIN.C:-
unsigned char asc,ok[2],r[4],a,i,oxoa, a,m[20],j,temp[10],temp1[10]; void cmdwrt_lcd(unsigned char cmd); void serial_transmit(unsigned char *srstr); void command(unsigned char d[]); void serial_tx(unsigned char srda); void delay1();
void gsm_send()
command("AT");
delay1();
delay(65000);
serial_tx('"');
serial_tx(0x0d);
serial_tx(0x0a);
delay(650);
serial_tx(0x1A);
delay(65000); delay(65000); delay(65000); delay(65000); delay(65000);
void gsm_send1()
delay(65000); delay(65000); delay(65000); delay(65000); delay(65000); delay(65000);
void wait_0x0a()
do
{ a=serial_rx();
} while(a!=0x0a); }
void rec_msg()
unsigned char i=0;
{ while(RI==0);
temp[i]=SBUF;
i++;
RI=0;
void check_ok()
{ unsigned char i;
temp1[i]=SBUF;
cmdwrt_lcd(0x80);
wait_0x0a();
check_ok();
temp1[2]='\0';
cmdwrt_lcd(0xc0);
void delay1()
void gsm_read()
{ command("AT");
cmdwrt_lcd(0x01);
for(j=0;j<=15;j++)
m[j]=SBUF;
RI=0; }
cmdwrt_lcd(0xC0);
display_lcd(&m[0]);
rec_msg();
temp[4]='\0';
delay1(); delay1();
{ motor=0;
gsm_send1();
CODE FOR SERIAL(SERIAL.c):-
#include <REGX51.H> #include"header.h"
void serial_init()
TMOD = 0x20;
TH1 = 0xFD;
SCON = 0x50;
TR1 = 1;
{ SBUF = srda;
while(TI == 0);
TI = 0;
serial_tx(*srstr);
srstr++;
unsigned char rbuf;
while(RI == 0);
RI = 0;
rbuf = SBUF;
return rbuf;
CODE FOR LCD(LCD.c):-
unsigned int i;
P1 = cmd;
rs = 0;
rw = 0;
en = 1;
delay(15);
en = 0;
delay(150);
P1 = datas;
rs = 1;
lcdstr++;
void lcd_init()
cmdwrt_lcd(0x38);
cmdwrt_lcd(0x0C);
CODE FOR HEADER FILE(header.h)
So, instead of just leaping in blindly, don't you think it would be a good idea spending some time to find out how to use it properly?!
Look at this picture: www.danlhenry.com/.../keil_code.png
Is that really so hard?
"i hope this is some wat readable..."
Don't just "hope" - use the Preview and verify for sure!!
MAIN.c:-
#include <REGX51.H> #include"SERIAL.c" #include"LCD.c" sbit rf=P2^0; sbit motor=P0^0; unsigned char asc,ok[2],r[4],a,i,oxoa, a,m[20],j,temp[10],temp1[10]; void cmdwrt_lcd(unsigned char cmd); void serial_transmit(unsigned char *srstr); void command(unsigned char d[]); void serial_tx(unsigned char srda); void delay1(); void gsm_send() { command("AT"); delay1(); command("AT+CMGF=1"); delay(65000); delay(65000); serial_transmit("AT+CMGS="); serial_tx('"'); serial_transmit("9710362655"); serial_tx('"'); serial_tx(0x0d); serial_tx(0x0a); delay(65000); delay(65000); serial_transmit("Vehicle Thefted "); serial_tx(0x0a); serial_transmit("Send Stop message to stop the vehicle"); serial_tx(0x0a); delay(650); serial_tx(0x1A); delay(65000); delay(65000); } void gsm_send1() { command("AT"); delay1(); command("AT+CMGF=1"); delay(65000); delay(65000); serial_transmit("AT+CMGS="); serial_tx('"'); serial_transmit("9710362655"); serial_tx('"'); serial_tx(0x0d); serial_tx(0x0a); delay(65000); delay(65000); serial_transmit("Your Vehicle has been stopped"); serial_tx(0x0a); delay(650); serial_tx(0x1A); delay(65000); delay(65000); } void wait_0x0a() { do { a=serial_rx(); }while(a!=0x0a); } void rec_msg() { unsigned char i=0; do { while(RI==0); temp[i]=SBUF; i++; RI=0; } while(temp[i-1]!=0x0A); } void check_ok() { unsigned char i; for(i=0;i<=3;i++) { while(RI==0); temp1[i]=SBUF; RI=0; } } void command(unsigned char d[]) { serial_transmit(&d[0]); cmdwrt_lcd(0x80); serial_tx(0x0d); wait_0x0a(); check_ok(); temp1[2]='\0'; delay(65000); delay(65000); cmdwrt_lcd(0xc0); } void delay1() { delay(65000);delay(65000);delay(65000); } void gsm_read() { command("AT"); delay1(); command("AT+CMGF=1"); delay1(); command("AT+CGSMS=1"); delay1(); command("AT+CMGD=1"); delay1(); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); display_lcd("Waiting for Msg"); for(j=0;j<=15;j++) { while(RI==0); m[j]=SBUF; RI=0; } delay1(); cmdwrt_lcd(0xC0); display_lcd(&m[0]); delay1(); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); serial_transmit("AT+CMGR=1"); display_lcd("AT+CMGR=1"); serial_tx(0x0d); wait_0x0a(); rec_msg(); delay1(); temp[4]='\0'; cmdwrt_lcd(0xc0); display_lcd(&temp[0]); delay1(); delay1(); if(temp[0]=='S'&& temp[1]=='t'&&temp[2]=='o'&&temp[3]=='p') { motor=0; cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); display_lcd("Vehicle Stopped"); gsm_send1(); } } void main() { serial_init(); lcd_init(); P0=0x00; display_lcd("VEHI.THEFT ALERT"); cmdwrt_lcd(0xC0); display_lcd("SYSTEM USING GSM"); motor=1; delay(65000); while(1) { if(rf==0) { cmdwrt_lcd(0x01); display_lcd(" VEHICLE THEFTED"); gsm_send(); gsm_read(); while(rf==0); } } }</prev> CODE FOR SERIAL:-(SERIAL.c)
#include <REGX51.H> #include"header.h" void serial_init() { TMOD = 0x20; TH1 = 0xFD; SCON = 0x50; TR1 = 1; } void serial_tx(unsigned char srda) { SBUF = srda; while(TI == 0); TI = 0; } void serial_transmit(unsigned char *srstr) { while(*srstr != '\0') { serial_tx(*srstr); srstr++; } } unsigned char serial_rx() { unsigned char rbuf; while(RI == 0); RI = 0; rbuf = SBUF; return rbuf; }
CODE FOR LCD.c:-(LCD.c)
#include <REGX51.H> sbit rs = P3^5; sbit rw = P3^6; sbit en = P3^7; void delay(unsigned int dela) { unsigned int i; for(i=0;i<dela;i++); } void cmdwrt_lcd(unsigned char cmd) { P1 = cmd; rs = 0; rw = 0; en = 1; delay(15); en = 0; delay(150); } void datawrt_lcd(unsigned char datas) { P1 = datas; rs = 1; rw = 0; en = 1; delay(15); en = 0; delay(150); } void display_lcd(unsigned char *lcdstr) { while (*lcdstr !='\0') { datawrt_lcd(*lcdstr); lcdstr++; } } void lcd_init() { cmdwrt_lcd(0x38); cmdwrt_lcd(0x0C); cmdwrt_lcd(0x01); cmdwrt_lcd(0x80); }
CODE FOR HEADER.h:-(header.h)
#ifndef HEADER_H #define HEADER_H extern void serial_tx(unsigned char); extern void serial_transmit(unsigned char *); extern unsigned char serial_rx(); extern void serial_init(); extern void lcd_init(); extern void display_lcd(unsigned char *); extern void datawrt_lcd(unsigned char); extern void cmdwrt_lcd(unsigned char); extern void delay(unsigned int); #endif
now any one can suggest me.....
DO NOT #include .c files
This is a very bad approach!
All AT commands give a response to indicate success or failure; you are ignoring these responses and just ploughing blindly on assuming success!!
In addition, AT+CMGS gives a Prompt when it is ready for input...
sir, that is equal to one(AT+CMGF = 1)..my friend types wrong in thread..but in coding we have done tht...u just tell, how we should avoid tht error of multiple public definition and un called segment...
Then,what should we do sir??
Maybe look at all the examples you got installed together with the compiler - don't they seem to sometimes contain multiple C files, without using #include to compile them?
