Hi All,
Using the LPC1343 with the usbhid_rom example (and several others..), I'm not able to get string descriptors for the device via lsusb. I'm wondering if this is an issue with the device/string descriptors or something going on with my linux distro (Centos 6)...
dmesg shows the following:
usb 6-1: new full speed USB device using uhci_hcd and address 68 usb 6-1: New USB device found, idVendor=1fc9, idProduct=0003 usb 6-1: New USB device strings: Mfr=4, Product=32, SerialNumber=72 usb 6-1: Product: NXP LPC13XX HID usb 6-1: Manufacturer: NXP SEMICOND usb 6-1: SerialNumber: DEMO00000000 usb 6-1: configuration #1 chosen from 1 choice generic-usb 0003:1FC9:0003.0004: hiddev96,hidraw0: USB HID v1.00 Device [NXP SEMICOND NXP LPC13XX HID ] on usb-0000:00:1d.0-1/input0
And cat /proc/bus/usb/devices shows:
... T: Bus=06 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 68 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=1fc9 ProdID=0003 Rev= 1.00 S: Manufacturer=NXP SEMICOND S: Product=NXP LPC13XX HID S: SerialNumber=DEMO00000000 C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms E: Ad=01(O) Atr=03(Int.) MxPS= 64 Ivl=1ms ...
However, lsusb shows:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 068: ID 1fc9:0003 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What's going on, where's the string for device 1fc9:0003? If I insert a mouse or something lsusb shows a sensible descriptor for that...
uname -r 2.6.32-71.29.1.el6.x86_64
Any ideas?
Thanks in advance, Peter
How about USBHID example on this code bundle?
Sample Code Bundle for LPC13xx Peripherals using Keil's MDK-ARM V1.06 (Jun 8, 2011) ics.nxp.com/.../code.bundle.lpc13xx.keil.zip
USBHID processes string descriptors a little differently from USBHID_rom If USBHID puts right string for lsusb, the problem lies in the ROM code on the chip.
Tsuneo
Hi Tsuneo,
Thanks for the reply. I got the same results (ie no strings) with USBHID, USBCDC, etc... I've also tried this on a Ubuntu box and got the same results so I'm running out of things to try...
Peter
For those interested, it seems lsusb pulls data from /usr/share/hwdata/usb.ids
Apparently on Ubuntu its in /var/lib/usbutils/usb.ids
