1.when i use printf with no var_args then the compiler should call puts instead of printf.
ex1:
#include <REGX51.H> #include <stdio.h> void main(void) { printf("This must call puts instead of printf"); }
Program Size: data=30.1 xdata=0 code=1103
ex2:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This must call puts instead of printf"); }
Program Size: data=9.0 xdata=0 code=168
The above code links the printf function from the library which is huge(produces 1103 bytes).But the compiler can use puts when there is no var_args given which is much smaller than printf(produces 168 bytes).
2.The Compiler must find and remove the duplicate constant strings
ex3:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=334
ex4:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=183
3.Bit Test instructions are not used when i actually test for the bit
ex5:
#include <REGX51.H> #include <stdio.h> void main(void) { if(P0^1) { P1 = 10; } } ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION main (BEGIN) ; SOURCE LINE # 6 ; SOURCE LINE # 7 ; SOURCE LINE # 8 0000 E580 MOV A,P0 0002 6401 XRL A,#01H 0004 6003 JZ ?C0002 ; SOURCE LINE # 9 ; SOURCE LINE # 10 0006 75900A MOV P1,#0AH ; SOURCE LINE # 11 ; SOURCE LINE # 13 0009 ?C0002: 0009 22 RET ; FUNCTION main (END)
In the above assembly output it should have used a single instruction JNB instead of three MOV,XRL and JZ.This is very basic anybody would object the assembly code produced.
I have not used the compiler much.But the compiler needs a look by the programmers at keil.
The above programs were all compiled with compiler optimisation level set to 9 & favour speed.
About 5 years back i compiled a c51 source code using keil. Now i recompiled the same source code with the latest compiler from keil and compared the two output .hex files. Unfortunately it produced exactly the same output.Here i was expecting some code and data size reduction as the compiler must be capable of optimising more.
It seems there was no improvement on the compiler side.
It is not a complaint but in the interest of improving the compiler.
regards,
S.Sheik mohamed
No dear Sheik: you need to know what you're doing and what you're talking about, before making baseless accusations!
The linker, you mean. And I don't think this is a correct statement.
