1.when i use printf with no var_args then the compiler should call puts instead of printf.
ex1:
#include <REGX51.H> #include <stdio.h> void main(void) { printf("This must call puts instead of printf"); }
Program Size: data=30.1 xdata=0 code=1103
ex2:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This must call puts instead of printf"); }
Program Size: data=9.0 xdata=0 code=168
The above code links the printf function from the library which is huge(produces 1103 bytes).But the compiler can use puts when there is no var_args given which is much smaller than printf(produces 168 bytes).
2.The Compiler must find and remove the duplicate constant strings
ex3:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=334
ex4:
#include <REGX51.H> #include <stdio.h> void main(void) { puts("This string gets duplicated as many time as i use it"); }
Program Size: data=9.0 xdata=0 code=183
3.Bit Test instructions are not used when i actually test for the bit
ex5:
#include <REGX51.H> #include <stdio.h> void main(void) { if(P0^1) { P1 = 10; } } ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION main (BEGIN) ; SOURCE LINE # 6 ; SOURCE LINE # 7 ; SOURCE LINE # 8 0000 E580 MOV A,P0 0002 6401 XRL A,#01H 0004 6003 JZ ?C0002 ; SOURCE LINE # 9 ; SOURCE LINE # 10 0006 75900A MOV P1,#0AH ; SOURCE LINE # 11 ; SOURCE LINE # 13 0009 ?C0002: 0009 22 RET ; FUNCTION main (END)
In the above assembly output it should have used a single instruction JNB instead of three MOV,XRL and JZ.This is very basic anybody would object the assembly code produced.
I have not used the compiler much.But the compiler needs a look by the programmers at keil.
The above programs were all compiled with compiler optimisation level set to 9 & favour speed.
About 5 years back i compiled a c51 source code using keil. Now i recompiled the same source code with the latest compiler from keil and compared the two output .hex files. Unfortunately it produced exactly the same output.Here i was expecting some code and data size reduction as the compiler must be capable of optimising more.
It seems there was no improvement on the compiler side.
It is not a complaint but in the interest of improving the compiler.
regards,
S.Sheik mohamed
No dear Sheik: you need to know what you're doing and what you're talking about, before making baseless accusations!
Tamir, I've seen compilers replace calls to printf with puts. IIRC it was Visual C++. You'll have a hard time arguing that this would be a useless optimization. And why are you accusing the OP of not knowing what he is talking about? His point is that the compiler doesn't implement many common optimization techniques found in many other compilers. And he is right. I don't think that writing about it in forums will change anything, but that's a different matter.
Actually, it's trivially easy to win that argument, because in the case at hand it would be worse than useless --- it'd be flat-out wrong. puts() doesn't do the same thing as printf().
Because he doesn't. While his first example is at least questionable, the other two are just wrong.
In item 2. his observation about strings constants not being folded is simply incorrect. One doesn't even have to look at generated code ... it doesn't even grow as much as it would have to if his complaint were true.
In item 3. his code doesn't do what he thinks it's doing --- there is no bit test in there.
Having actually looked at the examples, I can see that he is wrong about all of them. Obviously, I jumped to conclusions because I do believe that C51 isn't as good at optimization as it should be. The OP hasn't done his homework. Sorry for the noise.
You mean, isn't as good as it could be.
Yes, The compiler has removed the duplicate string i confirmed it. Very Sorry for the wrong statement.
But The other two are correct. The bit test and the printf to puts
Even though the printf function is a complete different & complicated one, when we use no var_arg ie when we use it only to print constant strings then it is completely equivalent to puts.Whether this is done by comiler or linker is not a quetion here. So there is no point in using bulky printf instead puts.
"3.Bit Test instructions are not used when i actually test for the bit
The processor's architecture allows for bit test instruction and the compiler did not use that single instruction but used three instructions instead.
Look again at your 'C' code - carefully!
Your 'C' code does not perform a bit test!
Your 'C' code is just using the standard 'C' exclusive-OR operator...
eli-project.sourceforge.net/.../c.html
docs.hp.com/.../ch05s21.html
www.tutorialspoint.com/.../c_operator_types.htm
