Ping failure by the change of 10M to 100Mbps
Hi!
I'm developing a project and it's working well at 10Mbps (_10MBIT_ define at LPC23_EMAC.c) with TCP protocol. The ping response is perfect:
ping 10.0.0.180
Disparando 10.0.0.180 com 32 bytes de dados:
Resposta de 10.0.0.180: bytes=32 tempo<1ms TTL=128
Estatísticas do Ping para 10.0.0.180:
    Pacotes: Enviados = 4, Recebidos = 4, Perdidos = 0 (0% de
             perda),
Aproximar um número redondo de vezes em milissegundos:
    Mínimo = 0ms, Máximo = 0ms, Média = 0ms
Code:
/* The following macro definitions may be used to select the speed
   of the physical link:
  _10MBIT_   - connect at 10 MBit only
  _100MBIT_  - connect at 100 MBit only
  By default an autonegotiation of the link speed is used. This may take
  longer to connect, but it works for 10MBit and 100MBit physical links.     */
#define _10MBIT_
//#define _100MBIT_
When I enable the auto negotiation or _100MBIT_ define only, I got ping failure:
ping 10.0.0.180
Resposta de 10.0.0.80: Host de destino inacessível.
Resposta de 10.0.0.180: bytes=32 tempo=999ms TTL=128
             perda),
    Mínimo = 0ms, Máximo = 999ms, Média = 499ms
Esgotado o tempo limite do pedido.
    Pacotes: Enviados = 4, Recebidos = 1, Perdidos = 3 (75% de
             perda),
             perda),
    Pacotes: Enviados = 4, Recebidos = 0, Perdidos = 4 (100% de
             perda),
Code:
//#define _10MBIT_
//#define _100MBIT_
or
//#define _10MBIT_
#define _100MBIT_
How can I solve this problem? Does anybody can help me, please?
I need to work at 100Mbps to increase my network performance. My RL-ARM TCPnet library version is the 4.12.
Thanks,
Rafael.
