sir i am using IAR for MSP430 compiler , getting some errors after clicking on the Debug without downloadingoption on compiler can any one tell me ho to minimize those errors? flash error: user error:Illegal opcode found on address 0x0;
and some errors in the Debug log
Fri Mar 04 15:49:34 2011: Download complete. Fri Mar 04 15:49:34 2011: Loaded debugee: D:\EDK\MSP430\t5\Debug\Exe\v.d43 Fri Mar 04 15:49:34 2011: Target reset Fri Mar 04 15:49:34 2011: Note! The debug session was started without downloading any code. Fri Mar 04 15:49:34 2011: There was 1 warning during the initialization of the debugging session. Fri Mar 04 15:51:10 2011: User error: Illegal opcode found on address 0x0 Fri Mar 04 15:51:10 2011: Unable to execute: driver error.
But this is a Keil site - their competition (I almost uttered "moron" but finally I didn't).
but i did,t find any good site other then this
if anybody knows please tell me answer
Contact IAR technical support/support forum, then. I doubt whether anybody here can help !
at least no reply
Did you try to contact IAR technical support?
Did you look at TI's own forums for their MSP430 product range?
Hey everyone, i tried compiling a code on IAR 6.10 for ARM microprocessor, specifically STM32w108. But i got the following error :
Error[Lc036]: no block or place matches the pattern "zi section __DLIB_PERTHREAD in errno.o(dl7M_tln.a)"
Error while running Linker[/color]
I am unable to figure what is the source of the error. surprisingly, the same workspace is working fine on IAR 5.50. If anyone has any ideas, pls help.
Why are you posting an IAR question on the Keil forum?
Could you not guess, just from the name, that this is the Keil forum and not the IAR forum?
Did you not read the forum description:
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products. " http://www.keil.com/forum/
You've posted in an existing thread - did you not read the foregoing discussion to see if your post was relevant? Did you not notice the previous comments about IAR?
"I am unable to figure"
Yes - it shows!
