hey, i am workin on arm 7 (lpc2148)...i have the following code for rtos bt there are some prblems in compilation of code. so plzz help. here is the code #include <LPC214X.H> #include <rtl.h> //#include <RTX_Config.h>
void delay(void);
OS_TID tsk_1; OS_TID tsk_2; // OS_TID init; unsigned int i; __task void task1(void) { for(;;) { IOCLR1=0X00FF0000; delay(); IOSET1=0X00550000; delay(); } }
__task void task2(void) { IOCLR1=0X00FF0000; delay(); IOSET1=0X00AA0000; delay(); }
void delay(void) { for(i=0;i<10000;i++) ; }
__task void init (void) { tsk_1= os_tsk_create (task1, 0); tsk_2= os_tsk_create (task2, 0); }
int main(void) { IODIR1=0X00FF0000; os_sys_init (init); }
AND FOLLOWING ARE THE ERRORS: Build target 'Target 1' assembling Startup.s... compiling code.c... compiling RTX_Config.c... linking... sa.axf: Error: L6218E: Undefined symbol os_sys_init0 (referred from code.o). sa.axf: Error: L6218E: Undefined symbol os_tsk_create0 (referred from code.o). sa.axf: Error: L6218E: Undefined symbol os_clock_interrupt (referred from rtx_config.o). sa.axf: Error: L6218E: Undefined symbol os_mut_init (referred from rtx_config.o). sa.axf: Error: L6218E: Undefined symbol os_mut_release (referred from rtx_config.o). sa.axf: Error: L6218E: Undefined symbol os_mut_wait (referred from rtx_config.o). sa.axf: Error: L6218E: Undefined symbol os_tsk_self (referred from rtx_config.o). Target not created PLZ HELP....
No errors in RTOS.
And no errors in compilation.
But have you remembered to ask the linker to link with the required library?
