Hi, I'm writing a code for digital clock in Keil C, but I'm not getting the expected results. Can anybody please help me with the program? The code is as follows..
#include <AT892051.H> #include <stdio.h> #include <intrins.h>
sbit PIN_P10=P1^0;/* Character to be transfered through this bit in parallel*/ sbit PIN_P11=P1^1;/* Clock*/ sbit PIN_P12=P1^2;/* Latch*/ sbit CS4=P1^3; /* 1st 7-segment Display*/ sbit CS3=P1^4; /* 2nd 7-segment Display*/ sbit CS2=P1^5; /* 3rd 7-segment Display*/ sbit CS1=P1^6; /* 4th 7-segment Display*/
unsigned char DataWrite; unsigned char _crol_(unsigned char Temp,unsigned char DataWrite); char Display_Buffer[6]; unsigned char Dispcount; unsigned char mscount;
int Hours=1; int Minutes=0; int Seconds=0; int i=0; char Temp;
code unsigned char Lookup[11]= { 0xEE,0x28,0xCD,0x6C,0x2B,0x67,0xE7,0x2C,0xEF,0x2F };
void main() {
TMOD=0x01; TH0=0xF8; /* Initializing timer0*/ TL0=0x30; /*for 1ms*/ IE=0x82; TR0=1;
do {
sprintf(Display_Buffer,"%02d%02d",Hours,Minutes); /* converting int into char*/
}while(1);
void Timer0(void) interrupt 1 { TF0=0; TR0=0; TH0=0xF8; TL0=0x30; TR0=1;
{ mscount++; Dispcount++; if(mscount>=1000) { mscount=0; Seconds++; } if(Seconds>=59) { Seconds=0; Minutes++; } if(Minutes>=59) { Minutes=0; Hours++; } if(Hours>=12) { Hours=1; } }
{ if(Dispcount==29) /* This code is for refresh rate*/ { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==30) {
DataWrite=Lookup[Display_Buffer[0]-0x30];
if(8>i) { i++; if (Dispcount==34) { Temp=DataWrite; } if (Dispcount==32) { PIN_P11=1; }
if (Dispcount==36) { PIN_P10=Temp^7; } if (Dispcount==38) { PIN_P11=0; } if (Dispcount==40) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0;
if(Dispcount==48) { CS1=1; } }
{ if(Dispcount==49) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==50) {
DataWrite=Lookup[Display_Buffer[1]-0x30];
if(8>i)
{ i++; if (Dispcount==54) { Temp=DataWrite; } if (Dispcount==52) { PIN_P11=1; }
if (Dispcount==56) { PIN_P10=Temp^7; } if (Dispcount==58) { PIN_P11=0; } if (Dispcount==60) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0; }
if(Dispcount==68) { CS2=1; } }
{ if(Dispcount==69) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==70) {
DataWrite=Lookup[Display_Buffer[2]-0x30];
if(8>i) { i++; if (Dispcount==74) { Temp=DataWrite; } if (Dispcount==72) { PIN_P11=1; }
if (Dispcount==76) { PIN_P10=Temp^7; } if (Dispcount==78) { PIN_P11=0; } if (Dispcount==80) { DataWrite=_crol_(Temp,1); }
if(Dispcount==88) { CS3=1; } }
{ if(Dispcount==89) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==90) {
DataWrite=Lookup[Display_Buffer[3]-0x30];
if(8>i) { i++; if (Dispcount==94) { Temp=DataWrite; } if (Dispcount==92) { PIN_P11=1; }
if (Dispcount==96) { PIN_P10=Temp^7; } if (Dispcount==98) { PIN_P11=0; } if (Dispcount==100) { DataWrite=_crol_(Temp,1); }
if(Dispcount==108) { CS4=1; } }
if(Dispcount==821) { CS1,CS2,CS3,CS4=0;
} } RETI;
So what results are you getting?
And what results did you expect?
And what thought, debugging, etc have you put into determining what might account for the differences?
For some tips on debugging, see: www.8052.com/.../120313
Note that the AT892051 is an MCS51 - not MCS251.
You also failed to notice the clear instructions on how to post source code:
www.danlhenry.com/.../keil_code.png
In programming, attention to these kinds of details is critical; so you first step should be to go back and check your code in detail for slips like that - eg, by stepping through it "manually" with pencil and paper: www.8052.com/.../174639
http://www.keil.com/forum/docs/thread17309.asp
