Digital clock program using 89C2051
Hi, I'm writing a code for digital clock in Keil C, but I'm not getting the expected results. Can anybody please help me with the program? The code is as follows..
#include <AT892051.H>
#include <stdio.h>
#include <intrins.h>
sbit PIN_P10=P1^0;/* Character to be transfered through this bit in parallel*/
sbit PIN_P11=P1^1;/* Clock*/
sbit PIN_P12=P1^2;/* Latch*/
sbit CS4=P1^3; /* 1st 7-segment Display*/
sbit CS3=P1^4; /* 2nd 7-segment Display*/
sbit CS2=P1^5; /* 3rd 7-segment Display*/
sbit CS1=P1^6; /* 4th 7-segment Display*/
unsigned char DataWrite;
unsigned char _crol_(unsigned char Temp,unsigned char DataWrite);
char Display_Buffer[6];
unsigned char Dispcount;
unsigned char mscount;
int Hours=1;
int Minutes=0;
int Seconds=0;
int i=0;
char Temp;
code unsigned char Lookup[11]=
{ 0xEE,0x28,0xCD,0x6C,0x2B,0x67,0xE7,0x2C,0xEF,0x2F
void main()
TMOD=0x01; TH0=0xF8; /* Initializing timer0*/ TL0=0x30; /*for 1ms*/ IE=0x82; TR0=1;
do
sprintf(Display_Buffer,"%02d%02d",Hours,Minutes); /* converting int into char*/
}while(1);
void Timer0(void) interrupt 1
{ TF0=0; TR0=0; TH0=0xF8; TL0=0x30; TR0=1;
{ mscount++; Dispcount++; if(mscount>=1000) { mscount=0; Seconds++; } if(Seconds>=59) { Seconds=0; Minutes++; } if(Minutes>=59) { Minutes=0; Hours++; } if(Hours>=12) { Hours=1; }
{ if(Dispcount==29) /* This code is for refresh rate*/ { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==30) {
DataWrite=Lookup[Display_Buffer[0]-0x30];
if(8>i) { i++; if (Dispcount==34) { Temp=DataWrite; } if (Dispcount==32) { PIN_P11=1; }
if (Dispcount==36) { PIN_P10=Temp^7; } if (Dispcount==38) { PIN_P11=0; } if (Dispcount==40) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0;
if(Dispcount==48) { CS1=1; }
{ if(Dispcount==49) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==50) {
DataWrite=Lookup[Display_Buffer[1]-0x30];
if(8>i)
{ i++; if (Dispcount==54) { Temp=DataWrite; } if (Dispcount==52) { PIN_P11=1; }
if (Dispcount==56) { PIN_P10=Temp^7; } if (Dispcount==58) { PIN_P11=0; } if (Dispcount==60) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0; }
if(Dispcount==68) { CS2=1; }
{ if(Dispcount==69) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==70) {
DataWrite=Lookup[Display_Buffer[2]-0x30];
if(8>i) { i++; if (Dispcount==74) { Temp=DataWrite; } if (Dispcount==72) { PIN_P11=1; }
if (Dispcount==76) { PIN_P10=Temp^7; } if (Dispcount==78) { PIN_P11=0; } if (Dispcount==80) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0; }
if(Dispcount==88) { CS3=1; }
{ if(Dispcount==89) { CS1=0; CS2=0; CS3=0; CS4=0; } if(Dispcount==90) {
DataWrite=Lookup[Display_Buffer[3]-0x30];
if(8>i) { i++; if (Dispcount==94) { Temp=DataWrite; } if (Dispcount==92) { PIN_P11=1; }
if (Dispcount==96) { PIN_P10=Temp^7; } if (Dispcount==98) { PIN_P11=0; } if (Dispcount==100) { DataWrite=_crol_(Temp,1); }
} PIN_P12=0; }
if(Dispcount==108) { CS4=1; }
if(Dispcount==821) { CS1,CS2,CS3,CS4=0;
} RETI;
